Question about Acer Aspire 5101WLMi Notebook
Acer Aspire 5101 battery light never goes off, even when the system is turned off. How is this physically possible? Is something plugged in to a usb port still drawing power or is it a software thing? Is it something in the bios that keeps the battery on? We've just had it back from being repaired cuz it was constantly overheating and they cleaned and repaired it but never mentioned the battery light so is it something wrong with our power adapter tho it cdn't be cuz it stays on when the mains is unplugged. Help this is driving me crazy and it can't be good for the battery.
There are three small lights; when I turn the machine on, the middle light goes on first and then the other lights go on. When the machine starts, the middle light flickers or goes off completely.
plug in the charger and let it charge the battery for 6 hours
operator manuals --go google - and type in--user manual for acer aspire computer , model at3-600-ur33-- and down load the pdf version
Sep 16, 2017 | Acer Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer aspire 5101 battery only lasting 3 minutes on full charge
The battery has possibly been on charge permanently as you laptop has been in use. This damages the battery and causes it to lose power.
Replace the battery.
Ebay have a good range and price.
Hope this answers your question.
Dec 29, 2010 | Acer Aspire 5101WLMi Notebook
Acer Aspire 5101 AWMLI. Keyboard & usb ports non functioning
I would check out ebay. I have seen them on there.
Nov 23, 2009 | Acer Aspire 5100 Notebook
I have Problems with Acer Aspire One AOA110-1113 Blue Intel Atom N270 8.9' 512MB Memory 8GB. it shows no signal on the screen. no light no cursor no nothing. only sound. and no physical damage. it just...
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a dikette won't work with a usb stick
May 17, 2009 | Acer Aspire One AOA110-1113 Netbook
When I push the ''on'' button with the computer plugged in, won't b
The battery is clipped at the bottom of the laptop, it sounds like the PSU circuit in your laptop has failed and you might want to consider taking it to a computer shop, but get quotes first as some shops still act like cowboys.
Nov 20, 2008 | Aspire Acer 53152826 Notebook
Acer aspire 5101 inbuilt cam driver required
If you have a grey rectangle where ur cam should be. Especially after a fresh install plus all the drivers. although Then here's your solution :)
Go into device manager and delete the USB controller. Then reboot. When it says new hardware found let it automatically install it. Et voila, working cam :)
Complements of TruthSeeker 69
Jul 19, 2008 | Acer Aspire 5100 Notebook
Acer 5101 AWLMI orbicam problem!
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Jan 12, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5101 orbicam
just double check that you havent loaded the Bison camera driver or the Vista driver as your system doesnt list the orbicam as being fitted, but you obviously have so go to the link below and download the logitech driver, as this is what i used http://support.acer-euro.com/drivers/ftp/ftp.html
Sep 02, 2007 | Acer Aspire 5100 Notebook
Open Questions:
Acer Aspire 5101WLMi Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
