Question about Refrigerators
Where to find fridge drawers & glass top for westinghouse silhouette 521 auto-defrost
  • Anonymous Feb 01, 2009
    I need a fridge drawers for Westinghouse model RJ 530.Where can i get? I'm living at South Yarra / Melbourne
  • 943 Answers
Hi. thanks for the question . I would try, Repair clinic. you will need the model # thanks the appliance doc
Posted on Oct 03, 2008
I have a westinghouse fridge freezer and it has a humidity drawer/crisper for the fruit and veges
then turn the dial at the top of the unit to a lower number . READ your manual
Sep 25, 2015 | Westinghouse Refrigerators
Have a westinghouse silhouette frost free 442 fridge freezer. It is full of ice behind the back panel. How can I remove the panel? Is there a simple way to defrost the ice? It is approximately 5 cm...
its easy to remove the ice ( just add heat ) / but you do need to correct the problem . this sounds like a defrost cycle failure .. ck the defrost heater and the defrost terminator . and the heater itself .. the model # is not complete try to find the one on the unit itself . in order to get better info .. hope this helps mmm. feed back pls.. 7/10 //11
Jul 10, 2011 | Westinghouse Refrigerators
Westinghouse Silhouette Frige 522 frost free is
Apr 24, 2010 | Refrigerators
Have a Westinghouse 'Silhouette' Frost Free 415
The reason your "freezing up in the freezer" is your unit is not automatically defrosting. That part you describe is your defrost control, or at least A defrost control. You said while cleaning the back, safe to assume you meant the outside back of the cabinet? Look for a square plug, either black or white, with the same 3-1plug as the defrost control. But, I doubt that is your current defrost control, maybe the original, but the unit cannot run without the defrost control plugged in. Now, your current defrost control maybe defunct, or your defrost heater element, or bi metal thermostat, the latter two are located in the freezer, one at the top, the other at the bottom of the evaporator coil. Test the continuity through both of these parts, the bi metal t stat at top of evaporator needs to be tested while it is cold. Disconnect one end of the heater element to test its continuity. If both of these test ok, replace your defrost control.
Mar 29, 2010 | Freezers
Cracked glass of Westinghouse silhouette Kitchen Cooktop
Bugger !
Price is model & country dependent.
Usually, it is easily be replaced. Lift out hob, keep right way up. Unscrew surround screws & lift glass off the base & guts. put new one on.
Dec 12, 2009 | Cooktops
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Check the back bottom freezer wall to see if there is frost on it. If so you have a defrost problem. If the coil dosent defrost it becomes an ice ball and no air can flow. Could be a defrost timer which switches the refrig into the defrost cycle. There is also a heater and thermostat in the system. Shut it off overnight with the doors open to defrost it and get it temporarily running . If it is not frosted up make sure your coil underneath is clean and your cooling motor is running in the back, bottom.
Jun 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
