Question about AOC LM729 17" LCD Monitor
Problem in monitor
I have ths AOC type of monitor and the menu for contrast etc... is keep on appearing i tried to put it in a rest the monitor for almost 24 hours still the box for menu is appearing is thereany solution for these....
  • hannor18 Oct 03, 2008
    rght now it appears to be normal again i just let it do whatever the monitor wants to do but still im kinda afraid t mght return again and thanks i will see..........
  • kerwinboi Oct 19, 2008
    hi. my monitor got the same too. it changes everything on its own. like the contrast, size of the screen, etc.. looks like somebody is remoting or what ever. please help me with this
    New Friend:
  • 62 Answers
1. First cheak the control panel microswitches. if any dry points on the panel ,solder the drypoints.
2. Replaced the microswitches
3. Cheak Control Proccer input voltage DC 5 V, from power section.
4. Changed the 7805 Reguletor. ( near to Control Procer )
Posted on Oct 03, 2008
Contrast box keeps appearing
Seems the menu button of the monitor is stuck. Turn off the monitor and the with the main power supply. Spray an air duster or w40. then try to push one after the other and check it the button is working much better now.
Feb 22, 2011 | AOC LM 720 17" Flat Panel LCD Monitor
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
Contrast menu keeps popping up in my moniter,it is a hcl moniter,the menu is not the normal adjustment menu that appears in the moniter which has all options like colour,brighteness etc.its just like a...
mmm look you have a setting problem reset the screen to it's defulat if it didn't solve the problem you will have to change the press bottoms and you will need some who know electronics to help you with the board but first try to rest it to the defulat settings
Nov 15, 2009 | ViewSonic VA721 17" LCD Monitor
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Apr 28, 2008 | AOC 7F 17" CRT Monitor
Monitor menu problems
Hai Ejor,
You need to replace the front panel menu buttons,
Regards
Aby
Nov 18, 2007 | AOC LM729 17" LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Contrast menu
don't buy this type of monitor because i have same problem as you... i realy hate this monitor...
Aug 22, 2007 | AOC CT720G 17" CRT Monitor
AOC LM729 17" LCD Monitor Logo
166 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
