Question about Zanussi FJS1225W Front Load Washer
I have problem E40 on Zanussi zwd 1680 w
Hello, has anyone had to solve an 'E40' on their Zanussi zwd 1680 W before? Any help very much appreciated
  • Anonymous Mar 18, 2014
    error code e36 on zwd 1272w please
  • Anonymous Mar 23, 2014
    DOES NOT TAKE SOAP
  • Zanussi Master
  • 19,396 Answers
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Posted on Oct 15, 2008
I have a Zanussi Washer/Dryer Model ZWD 1270W. When I set the machine to wash (any cycle), it fills with water, the water jet starts, it takes the soap powder then it immediately skips to the 'drain'...
http://laundry.manualsonline.com/manuals/mfg/zanussi/zwd_1270_w_zwd_1270_s_zwd_1470_w.html
If you go to this website, they have manuals and you can ask questions also.
Just one thought. Have you unplugged the washer for a few seconds then plugged it back in? It's possible the "brain" needs to be reset.
Nov 02, 2013 | Zanussi Washing Machines
Error e40 come up on my washing machine zwd 1472 s
E40 normally points to a fault at the door switch,sometimes when the door switch fault occurs it can also cause damage to the main P.C.B.(Programmer).As this machine is still in the major parts warranty it would be advisable to get in touch with Electrolux.
May 03, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Error codes E40 andE70 showing on model zwf1640s(zanussi)
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos,where the door striker pin goes through hole.
Held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
Check the Door Switch/interlock or the WIRING for failure in this case and repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Washing Machines
Zanussi ZWD 1680 W drainaing problen
Sounds like a split cabinet. There are screws behind the plastic caps at side of machine.remove lid and remove screws to rear of split on both sides and at bottom rear of machine. tease out plastic frame holding mains cable and the back end can now be removed.
Nov 13, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Oct 09, 2008 | Washing Machines
Washer dryer zwd 1480 zwd 1680 when i put a wash on after a couple of minutes it shoots down to 3 minutes and finishes. any ideas????
I have exactly the same problem, I am doing some testing with mine at the moment and I believe it to be one of the two thermostats in the heating chamber.
If you was to remove the top cover you'll find a long silver cilinder running through the middle of the unit. Looking from the front there are two modules on the left side (thermostats) with 2 wires connected to each towards the back of the dryer. These measure the temperature inside the heating chamber, on removing them the heat stays on, you have probably noticed the dryer is not even getting hot so the moisture sensor won't pick up any moisture in the air so the dryer trying to be cleaver with think the clothes inside are dry and finishes the cycle early.
I wouldn't reccomend removing these thermostats as it will probably overheat and cause a fire risk, however they should only cost a couple of ££ to replace.
Now I've just got to try and source the parts!!
Aug 24, 2008 | Zanussi FJS1225W Front Load Washer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Door closed, but getting error E40
Look for solved probs in this site, you are sure to find something abt unlocking your door without a prob. You can look thru your model for solved probs.
Apr 07, 2007 | Zanussi FJD1466S Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
1,082 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
