Question about Sharp 32SC26B 32" TV
High pitch there a high pitch noise coming out of the tube it just started dont know wher it coming from. picture is good as well as sound. TV is a 32" sharp 32sc26b. Is the tube going out? Can this noice be fixed very annoying please help.
    Scholar:
  • 142 Answers
I have never heard a tube make noise when there is a good picture. Anyway, the noise has to be a transformer ringing or oscilating. They make a high pitched squeal when they have a loose winding or their cover is loose. You probably won't be able to feel or see anything loose on these transformers The power supply switching transformer is the first to look at. Take a hot glue gun and just cover the thing...especially at the base of it. The next (and only other) one is the horizontal drive transformer.It is located close to the high voltage transformer( biggest thing on board and usually in back or corner of the PCB.This one wont squeal) The horizontal drive transformer is about the size of a large marble and is encased in a black plastic cover. Cover it with hot glue also.
If you take the back off you will probably be able to localize where the squeal is coming from. You will probably need a signal to hear the noise also. After you find where it is coming from UNPLUG the set before doing any hot gluing!!!!
If you 're not up to this procedure take it to a technician. Your tube is not going bad and the set is definitly worth repair. Simple fix!! Good Luck!!
barneyluc
Posted on Oct 03, 2008
  • 467 Answers
The high-pitched noise in some CRT type sets can either be a transformer in the line drive stage, the power supply, or the deflection yoke on the back of the tube itself could have vibrating windings. Picture tubes as a rule, generally do not 'whine'.
My experience has shown it to be mostly the yoke which causes the most trouble, and leads people to believe their tube is going out.
Rather than replacing the yoke, which isn't cost effective, you could carefully remove from base of tube, dip it in varnish (masking the areas which make contact with the tube of course as well as the rubber caps) this should secure the windings and stop the vibration or 'noise'.
BUT you MUST be aware of its original alignment to the CRT before you undertake removal. This works for Philips sets with loose yoke and small transformer windings.
Hot glue works on small chokes/transformers on the main board though, so you can try that also, but you must be exceptionally careful while doing so, and only use a small amount.
Only do this if you are prepared to accept any risks involved.
Posted on Feb 15, 2011
I have a samsung neo 32 inch picture tube tv. When I turn it on there is no picture or sound, but there is a light high pitched noise.
That high pitched sound is likely the Horizontal Output section trying to work. It operates at 15,750 Hz or at the upper end of normal human ears.
It will sound like a high pitched whine.
This is a section or your television that you don't want to fool with unless you are quite familiar with servicing your set. There are very high voltages involved and only a qualified technician should tend to this defect. It maybe easy to fix or it may be quite involved. Get an estimate first then decide to go further or not. There is a potential fire hazard here so don't operate your set until this is resolved.
Zashiban
Jun 23, 2010 | Samsung DynaFlat TX-P2764 27" TV
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
High pitched noise from inside the TV when picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Televison & Video
High pitch sound comming from tv!
The horizontal transistor and the flyback are damaged
Apr 24, 2008 | Samsung TX-P3264 32" TV
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
Sharp 32SC26B 32" TV Logo
226 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
