Question about HP Photosmart D7160 InkJet Printer
HP Photosmart just spits paper out
Many times when I try to print something with my new HP Photosmart D7160 it spools and then grabs the paper and just spits it out of the other end without printing the required document. I cant work out why it does this, any help would be appreciated.
  • anjelus Oct 13, 2008
    It seems to do this only in portrait mode. When I print in landscape mode it reduces the image size to 1/3rd the size even if I select print at full size..
5 Suggested Answers
SOURCE: hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Posted on Dec 13, 2007
geekofcomp
  • 47 Answers
SOURCE: Spools but does not print
try replacing the ink cartridges
make sure they are properly seated
hope this helps
Posted on Apr 10, 2008
PeteG0429
  • 34 Answers
SOURCE: printer spits out blank page
This should solve this problem if you haven't already. It's real simple.
Posted on Apr 02, 2009
PeteG0429
  • 34 Answers
SOURCE: One extra blank page coming out for each page actually printed
There you go. Good luck!
Posted on Apr 14, 2009
PeteG0429
  • 34 Answers
Here you go...
Posted on May 18, 2009
I have a HP Photosmart D7160 and it won't print 4 X 6. It has black marks on the wrong side when it comes out, but not picture
Try flipping the paper. Probably you need to resize the image for this size, sounds like it is compressed and squnched together into those black marks. See if you can use a preview function.
Jul 31, 2016 | HP Photosmart D7160 InkJet Printer
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
Sep 20, 2008 | HP Office Equipment & Supplies
HP d7160 won't print black, New cartridge. Goes through the motions - but nothing hits the paper. Colors print fine. What gives?
1. Turn printer off and disconnect the USB cable from the PC to printer
2. Uninstall the printer driver and software-->here's how.
Navigate here for printer driver and software .(Select your Operating System and click next)
Install the printer driver and software -->here's how
Feb 23, 2011 | HP Photosmart D7160 InkJet Printer
Hi, I've got an HP Photosmart D7160. It continually says "Paper Jam". Actually the error screen says something like "please remove paper jam and then press OK", but there is no paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.get more help and information for hp printer support hope this helps you.
Thanks
Michel
Feb 21, 2011 | HP Photosmart D7160 InkJet Printer
My printer is now 2 years old. Always done great, nothing happened. But now he can't get the A4-paper out of the tray. He trays to grab the paper, but it doens't work. Photo's out of the photo-tray is...
Looks like you have a paper jam problem.Pieces of paper are stuck in the roller.Go to Control Panel ->Printers and Fax -> Select you printer and click properties.You will find a Printer Maintainance Wizard,which will have a paper jam clearing wizard.Click this and your printer will work as good as new.
Thank You.
Feb 20, 2011 | HP Photosmart D7160 InkJet Printer
My Photosmart D7160 is telling me to turn my paper over as it seems to think the print side is on the back - how can I override this? Thank you
When you want to print something do it via file, print, and a screen should appear with the printers available but also with the properties button. Click the properties button. On the appeared tab with the settings there should be a check box to automaticly select the paper based on sensors. Uncheck that box, click OK, OK and it will not prompt you during this job. If you want to permanently switch this off, go the the same properties tab via start, configuration, printers and scaaners (in XP).
If you use the printer to print direct from a memorycard, go the the settings of teh printer and look for the automatic paper selection setting to switch it off.
Jan 15, 2009 | HP Photosmart D7160 InkJet Printer
Printing Problems!!!!! Help!!!!!!
You have the wrong drivers in your computer, go out to hp.com and download new drivers and software, once installed you should be inbusiness.
Aug 06, 2008 | HP PhotoSmart C4280 Laser Printer
Hp photosmart d7160
hp photosmart d7160
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
Printer cannot grab paper,
The rollers in these printers go bad all the time. Your best solution would be to take it to a local printer shop and get the rollers replaced.
Jul 19, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
