Question about Whirlpool GR465LXLS Electric Kitchen Range
Stove top light does not turn off - Whirlpool GR465LXLS Electric Kitchen Range
  • fidelcjr Oct 03, 2008
    my stove burner had a short and I had to replace the coil. Now the stove light does not turn off.
    my stove top burner (coil), had a short. I replaced that coil with a new one. It does heat up normal, however, the stove light does not turn off. The coil turns off, but the light stays on. what could be keeping the light on?
    Sergeant:
  • 208 Answers
There will be infiite switch in your stove,
It could be that infinite switch that needs to be changed...
Hope my info solves your problem......
Posted on Oct 03, 2008
  • 1,879 Answers
Does the stove heat up ?
isolate problem if it's only the light or something else
provide additional details please
  • Whirlpool Master
  • 19,396 Answers
Try first unplugging the power cord for ten or twenty minutes, check that the door is closing well.
If the problem persist, it may be a faulty control panel or a faulty part (thermistor, element, control, short etc.)
Post here the exact mmodel number to get a more detailed solution.
  • Ginko
    Ginko Oct 03, 2008
    If you just replaced the coil, that means that you probably did not fit the part in place in the proper way.
    Check the assembly of the replaced part, use a tester to find out were the contact is , you caused a contact, and that is the reason why unit stays on.
    You still did not post the model number, well, if you need schematics and diagrams insert model number here.
  • Ginko
    Ginko Oct 03, 2008
    Many cookers have also a reset button, keep it pressed for ten seconds and see if it help , even if I don't think this can fix it.
    As said, if there is no error code red light is steady, a contact or a faulty control assembly. The coil shorting may also have caused a fault in the control PCB, where you see the light, in this case you will need to replace the part.
    If the panel is faulty, you will need to test components using a multimeter.
    If model is the one posted in title, here is control panel assembly
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
Apr 12, 2008 | Hotpoint RB787 Electric Kitchen Range
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GR465LXLS Electric Kitchen Range Logo
119 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
