Question about HP Pavilion dv9720us Notebook
Unknown device thank you very much for your solution ,I hope receive more solutions from you,I still have unknown device,device instance id is( ACPI\HPQ0007\2&DABA3FF&0) location on microsoft ACPI compliant system(code28) ,and I have another unknown device it called ethernet controller ,device instance id is(PCI\VEN-10DE&DEV-054C&SUBSYS-30CF103C&REV-A2\3&2411E6FE&0&50),location PCI bus 0,device 10,function 0 (code28), and the (OHCI compliant IEEE 1349 host controller)cannot start,I must tell you that I upgrade my computer to xp,thank you very much and I hope receive your answer as soon as possible
  • 186 Answers
I beleive that you had downgraded and installed a retail version of XP by erasing the preinstalled version of Vista in your Notebook.
However, all the drivers required for your Notebook may not be available with HP if your Notebook is preinstalled with Windows Vista.
I recommend you to try downloading and installing the drivers for HP Quick Launch Buttons from the link below for the first Unknown device in the Device Manager :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
Save the file on to the Desktop or My Documents folder and double click once the download is completed to install the drivers.
For the Ethernet Controller, I recommend you to download the LAN Card Drivers from the link below :
ftp://210.51.181.211/cn/nic/INSTALL_VISTA_6208_0922.zip
Coming to IEEE 1394 controller, you need to download and install the Chipset Drivers which are available through the link below :
http://us.download.nvidia.com/Windows/nForce/15.24/15.24_nforce_winxp32_international_whql.exe
Make sure that you download and save the files in the Notebook and double click them once the download is completed and restart the Notebook after installing each of the drivers provided above.
Hope this helps...
Posted on Oct 06, 2008
Unknown device win 7
Usually, when you buy any hardware the drivers come along with it on a disc. If you lose the driver disc you can always download the necessary drivers from the manufacturer's website. But what do you do when you are not sure of the manufacturer of the hardware? Well now you will know what to do.
Open Device Manager (Control Panel>System>Hardware>Device Manager) The hardware whose drivers are missing will appear as Unknown device, so it's easier to locate the device. Right click on the unknown device and click on Properties. Under the Properties window click on Details tab and select Device Instance Id from the drop down box. You should see a code similar to this: PCI\VEN_8086&DEV_27DC&SUBSYS_30868086
& REV_01\4&1E46F438&0&40F0 In the text above the Vendor ID and Device ID will always be in the same place for the driver Vendor ID = 8086 and Device ID = 27DC your numbers will be different. Once you have obtained both the IDs, proceed to PCI Database. There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID. http://www.pcidatabase.com/
b>Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Hope this helps. b>
Dec 07, 2012 | HP Compaq nc6400 Notebook
Audio not aktif
Try to go throw this tutorial and fix it your self
if you think you have a driver problem go trow this steps
  1. Open Device Manager (Control Panel>System>Hardware>Device Manager)
  2. The hardware whose drivers are missing will appear as Unknown device, so it's easier to locate the device.
  3. Right click on the unknown device and click on Properties.
  4. Under the Properties window click on Details tab and select Device Instance Id from the drop down box.
  5. You should see a code similar to this
    &REV_01\4&1E46F438&0&40F0
  6. Give me this codes i will post the link to your driver
I hope you find this information useful and if you need any further assistance,
please feel free to contact me and let me know. I hope this information was helpful...
Have a nice day...
Mar 15, 2011 | Computers & Internet
XPS 210 with XP Media Center has unknown driver in device manager. I think it might be the TV tuner because I get a Decoder error when I try to watch TV in the media center.
Here's something to try. In Device Manager, double-click the unknown device to open its properties. Click the Details tab. In the Property drop-down menu, choose Device Instance ID (or Device Instance Path for Windows Vista/7). You'll see a string of characters in the Value box.
In this string of characters, look for the letters VEN_. The numbers following this are the vender ID. Then look for the letters DEV_. The numbers following this are the device ID.
Go to the PCI Vendor and Device database here:
and enter the vendor and device ID for your search. This doesn't always find the right device, but it often does. After you figure out what the device is, you should be able to determine whether you can download the right drivers.
Feb 26, 2011 | Dell My XPS 210 (dxcwpf1_7) Intel Core2...
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Running windows XP home edition get message USB
Try reinstalling the motherboard drivers, maybe something is wrong with the USB controller.
Jun 07, 2009 | Computers & Internet
Multimedia audio controller
This indicates that the sound drivers are missing from your computer. You will have to identify the sound card that is installed on your computer before proceeding with downloading the correct driver. To identify the sound card, follow the steps below (Assuming that you are using Windows XP)
  1. Open Device Manager (Right-click My Computer>Properties>Hardware>Device Manager)
  2. The hardware whose drivers are missing will appear as Unknown device, so it’s easier to locate the device.
    PCI\VEN_8086&DEV_27DC&SUBSYS_30868086&REV_01\4&1E46F438&0&40F0
  6. The portion of the code highlighted in RED is the Vendor ID and the portion highlighted in GREEN is the Device ID. In this example:
    Vendor ID = 8086
    Device ID = 27DC
  7. Once you have obtained both the IDs, proceed to www.pcidatabase.com . There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
Mar 25, 2009 | Acer Computers & Internet
I reinstalled Windows XP on my laptop and don't know what etherne
You should first check device manager for any issues with Network drivers.
Start--> Run --> devmgmt.msc
This command will launch "Device manager" window.
If you see a Yellow exclamation mark in device manager for NIC, follow the following steps to identify the card that is installed on your computer.
    Vendor ID = 8086
    Device ID = 27DC
After you find out the information about the device and the manufacturer of the device, you can visit the manufacturer’s website and download the corresponding device drivers.
Mar 23, 2009 | Dell Precision M20 Notebook
No dound and no soung driver found
The first issue is that you do not know what drivers to install. For this, you will have to identify the devices that are installed in your computer. To do this, follow the following steps:
    Vendor ID = 8086
    Device ID = 27DC
  7. Once you have obtained both the IDs, go to www.pcidatabase.com. There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
Once you know which device is installed in your computer. You can search for the driver and download & install the same.
Mar 22, 2009 | Microsoft Windows XP Professional
I need Drivers please send a copy of VGA drivers
First you will have to check the device that is installed on your computer and then download the drivers for the same. Go through the following steps to install the drivers:
  2. The hardware whose drivers are missing will appear as Unknown device, so it’s easier to locate the device. In your case, it will be VGA device.
    Vendor ID = 8086
    Device ID = 27DC
  7. Once you have obtained both the IDs, proceed to www.pcidatabase.com. There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
Mar 09, 2009 | Microsoft Windows XP Professional
HP Pavilion dv9720us Notebook Logo
2,476 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
