Nintendo DSi XL Burgundy Logo
Trojka Williams Posted on Dec 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No access point in range error code 051099-1
Unable to connect to internet i have wireless router error code 051099-1
david willimes
Level 2:
Sergeant:
  • Nintendo Expert 260 Answers
  • Posted on Oct 07, 2015
david willimes
Nintendo Expert
Level 2:
Sergeant:
Answers
260
Questions
0
Helped
120916
Points
563
  1. Create a new connection:
  2. Trying to play online multiplayer with Nintendo DSi
  • Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
  • Scroll over to the third page, and select "Internet."
  • Now choose "Connection Settings."
  • Click on "None" for "Connection 1."
  • Click on "Search for an Access Point."
  • The Nintendo DSi will search for any wireless networks within range
  • What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
for more help visit https://cbrtechsolutions.net
3 Related Answers
Push28
Luc Francoeur
  • 102 Answers
  • Posted on Jul 08, 2009
SOURCE: What do I do now?
try configuring your router with wep security
Anonymous
  • 713 Answers
  • Posted on Feb 22, 2011
SOURCE: i have tried t connect to the internet on my
hook a router up to a computer with security lock on routeroff.
Anonymous
  • 17 Answers
  • Posted on Mar 06, 2011
SOURCE: when my son tries to
This is a problem with the security settings on your browser. To do what you were doing when the error code appeared, change your security type to WEP, or disable security.
hope this helps.
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Error 051099 -1
How to Connect Nintendo DSi to the Internet
Instructions
1 You must either have broadband internet access and a wireless router or you can connect your Nintendo DSi at a hotspot, such as a library or coffee shop that offers internet access. Make sure you are in a location mentioned above before going to step 2.
2 Turn on your Nintendo DSi and click on the wrench icon. This will take you to the system settings.
3 Go to page 3 and select "Internet".
4 Click "Connection Settings".
5 Click "None" to the right of "Connection 1".
6 Click "Search for an Access Point".
7 Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DSi should now be connected.
8 If you are planning on playing games online with your Nintendo DSi and have WPA security, you will have to set your router to WEP security.
To do this, get back to the "Connection Settings" screen mentioned in step 4.
Click "Advanced Setup".
Click any button that says "none".
2answers
How do you get the internet on this my says no compatible access point in range check your connection setting under internet opion and try again error code 051099
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
  1. Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step.
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
mr_fix3er_0.png 2- Scroll over to the third page, and select "Internet."
mr_fix3er_1.png 3-Now choose "Connection Settings."
mr_fix3er_2.png4-Click on "None" for "Connection 1."
mr_fix3er_3.png 5-Click on "Search for an Access Point."
mr_fix3er_4.png 6-The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network.
7-What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
mr_fix3er_5.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_6.pngWEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_7.pngWPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
  • Other suggestions :
  • Make sure your router is set to broadcast in "b" or "mixed" mode. If your wireless router is transmitting in "N" only mode, you will need to switch it to "b/g" or "mixed" mode. For help accessing your router's settings, click here and select your router brand and model (if available). Most routers will have this setting in the "broadcast settings" menu.
    • Check for wireless interference, which can affect the signal strength to the Nintendo DS. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Nintendo DS is an open area without objects or electronics blocking the signal.
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • Still stuck? We can help! We have found that simply erasing the old connection file and creating a new connection to your router may help. Click the button below for a step-by-step guide. If at the end you still need help, you'll find contact information to reach our specially-trained representatives. Click the button below for your system and we'll walk you through the connection step-by-step.
    1helpful
    4answers
    Internet access on the nintendo DSI is saying no compatible access point in range check your connection settings under the internet option and try again error code 051099 we dont know the ssid code to...
    The nintendo dsi needs a wireless router transmitting in MIXED mode, meaning that it transmits using B mode as well as G or for newer routers N mode. If it is setup to transmit in G or N only, then the DSI will not detect it.
    Also, the DSI is not compatible with WPA security. You need to set up a weaker WEP security code or turn off wifi security altogether.
    Also, make sure the router is broadcasting the SSID name which is the name of the wireless router.
    for more information: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
    I tried to contact the internet and it keep on saying your error code 051099 and i wanted internet
    Hi tabia tabz, Nintendo has an excellent walk-through on fixing just that issue. Instead of just re-ryping their information I will post it exactly as they had it because they offer very nice images of exactly what you need to do each step which should help you alot.
    Here is what Nintendo states:
    Error Code: 051099 Was this information helpful?Unable to use your wireless signal
      Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.Try this:
      1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
      2. Scroll over to the third page, and select "Internet."
      3. Now choose "Connection Settings."
      4. Click on "None" for "Connection 1."
      5. Click on "Search for an Access Point."
      6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network.
      7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
          unlocked.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_compatible.png WEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_wpa.png WPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
    3. Other suggestions:
    5helpful
    2answers
    Error code 051099"1 nintendo dsi.trying to get
    Error Code: 051099Was this information helpful?
    Here's a link:
    http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
    DONT FORGET TO RATE THIS PLEASE
    Error code 051099 keeps coming up.
    Error Code: 051099 This error code can occur for two different reasons:
    • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
    • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
    There appears to be a compatibility issue with the security settings on your router:
    Are you using WPA security?
      No, I am using WEP security
    If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
    • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
    • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
    • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
    • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
    • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
    • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
    • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
    If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
    • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
    • Configure the Nintendo DSi or Nintendo DSi XL manually
        Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
    CANT GET ON INTERNET
    Top Nintendo Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Aron
    Sean Wright
    Sean Wright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
