Question about Acer Aspire 5315 Notebook
Unknow flashing lights one green /one red
My dam lights keeps on flashin on my computer ??? not sure what it does and i dont have manual book for my acer aspire5315 can anyone help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Sergeant:
  • 208 Answers
Read this manual www.scribd.com/doc/2505575/Acer-Aspire-Laptop-manual
Page no: 17 in this manual is about status indicators...
Hope this helps...
Thanx for using fixya......
Posted on Oct 03, 2008
  • 25 Answers
Can u tell it me in a little detail...
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Shut off, light is flashin red, when you try to turn it on light goes green then yellow then flashes red again
this is a hard drive problem. if you remove the hard drive from the side of the consol (make sure its unplugged) clean the connections then replace it all it should work. if not you require a new hard drive im afraid
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 Light Keeps Flashin Green/Yellow/Red
There are some reasons of PS3 goes red/green/yellow light and flashing red then turn off. But don't waste money to find someone to fix it yet! It may be a minor issue that you can be fixed by yourself.
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the same problems after bought this guide. The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Ultimate Repair Guide
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
When i try to put sons on my ipod they show up on my computer screen so that it looks like there are songs on it but when i disconnect my ipod shuffle the songs dont play and a light flashes green red...
Are you sure its green red green red or is it green orange green orange?
Because according to apple, it doesnt have a sequence for green red green red..... either way, you can see what the different lights mean here..
http://support.apple.com/kb/HT1407?viewlocale=en_US
Thank you and please be sure to rate this answer... :)
Sep 24, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Acer Aspire 5315 Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
