Question about Asrock K7S8X-R3 Motherboard
My PC won't work with 3Gb of RAM
If I try to upgrade my memory from 2.5Gb to 3Gb, my PC will not work at all, despite the fact that I am using PC2100 memory, and the memory is recognised by BIOS. I have tested my 1Gb memory modules, and they are good. Any suggestions as to what the problem is?
    Genius:
  • 1,250 Answers
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Posted on Oct 03, 2008
How to know that the ram can match with your motherboard?
This motherboard supports DDR200/266/333 SDRAM
The memory needs to match one of these numbers so:
DDR200
DDR266
DDR333
one of these types will work
This motherboard will support a maximum of 4GB of memory.
Apr 13, 2011 | ASUS VIA KT333 Chipset A7V333...
I had just one memory module on this motherboard which was kingston ddr, 256mb, pc2100. Then i upgraded my mobo with one stick of pc3200 ddr ram, and it keeps restarting and sometimes it just turns off...
PC 3200 is not supported by this motherboard. It will cause problems. You need to use PC2100 RAM.
http://www.motherboards.org/reviews/motherboards/988_2.html
Hope this helps.
Sep 27, 2010 | FIC VC 11 Motherboard
What type of memory do i use with this motherboard
You can mix the memory but there is a down side to this. If you install PC1600 & PC2100 the motherboard will lower the speed of the PC2100 to match the slower PC1600 memory. The SY-P4VDA MB uses, DDR266 PC2100, 184p DIMM, 2.5volt memory up to 3Gb. If you wish to buy memory for your board you can click on the link provided for an idea of prices for PC2100 DDR266;
http://www.google.com/products?hl=en&source=hp&q=soyo+sy+p4vda+memory&um=1&ie=UTF-8&ei=SB_ESqqYHYKN8AbXkelJ&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCIQrQQwAw
DDR200 PC1600, 184p DIMM, 2.5v, Sync, CL=2
http://www.google.com/search?hl=en&q=PC1600+DDR200+184p+DIMM%2C+2.5v%2C+Sync%2C+CL%3D2.5&btnG=Search&aq=f&oq=&aqi=
Cheers!
Mike
Sep 30, 2009 | Soyo SY-P4VDA Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Unable to get 3GB of memory to work on the motherboard
Hi enj1956, according to the manual the MB supports only,
"one" DIMM of DDR400MHz.
See page 2-7 in your manual.
You can use 3, PC2700/DDR333 / 3, PC2100/DDR266 or
3, PC1600/DDR200 to reach the 3GB.
All DIMMs must be the same memory type & speed.
MSI KT4V (MS-6712) link;
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=505
Good luck enj1956!
Any more questions?
Happy holidays!
Mike
Dec 23, 2008 | MSI KT4V (MS-6712) Motherboard
OS not showing full RAM
Hi Shibbymusic, as with most Asus boards if not all! The MB
A8N-E does not show all of your 4GB memory. See this FAQ;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=A8N-E&os=17
Like you, I too have 4GB of memory.
Asus A8N32-SLI Deluxe w/4GB memory only see's 3GB
The bios displays 3GB during boot up & so does windows XP 32bit.
You might want to think about upgrading to 64bit os.
Updating your bios should help as well.
(See A8N-E Bios version 1010); http://support.asus.com/download/download.aspx?modelname=A8N-E&SLanguage=en-us
Thank you for using fixya!
Mike
Dec 07, 2008 | ASUS A8N-E Motherboard
Choosing/upgrading DDR memory
hi there,
i dont see why u should not upgrade to 1gig RAM ... but u should stick to one memory speed ...and Size but if u can try to get the PC2700 - DDR400Mhz memory
Apr 14, 2008 | Syntax SV266A SKA KT266A Motherboard
DDR & SDRAM supported?
I suggest you stay within your manual specs.
Your boards memory should not use voltage higher than CL2.5
Below is a link for 1Gb dimm DDR266 PC2100. CL2.5
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80388-1
You can also buy two which would take you to the motherboards MAX memory of 2Gb.
Dec 30, 2007 | Jetway V266B Motherboard
Asrock K7S8X-R3 Motherboard Logo
217 people viewed this question
Top Asrock Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Mark Taylor
Mark Taylor
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
