BenQ monitor stops displaying picture, but shows blue light indicating that it is on.
    Problem Solver:
  • 47 Answers
Is the vga connections in correctly?
if the computer is new and it has a graphics card, then it will need to be plugged into the graphics card vga socket instead of the onboard vga socket.
it may also be a graphics card fault, try using another card, maybe borrowing one off a friend.
hope this helps.
kev
Posted on Oct 03, 2008
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
May 28, 2017 | BenQ PB6100 Multimedia Projector
~Hello! My monitor dispays picture, but the picture isnt like it should be. Instead of normal colours it displays gray stripes, red is shown as yellow, windows 7 startup icon is in black box ect. When...
Hey, have you bene able to try another monitor and see if its the same thing?
Check andmake sure that all of your cables are tight and secure. If they are then you probably have a bad video card. they are fairly easy to replace:
Jul 15, 2011 | BenQ FP737S-D 17" LCD Monitor
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
Benq G900W Monitor: Settings show as generic non-PnP monitor and
for that purpose you have to insert an AGP card into AGP slot of grade 8X then you can see full resolution because the inbuilt display card does not support to high resolution
Mar 05, 2010 | BenQ G900W Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Problem with controler
The problem is defective keys/switches of front key PCB.You need to replace this key PCB or Individual keys.
Normally Benq Offers a 3 yr warranty Try contacting BenQ.
Please rate the solution and provide feedback.
Samir
May 15, 2008 | BenQ FP731 17" LCD Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Secondary monitor
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Mar 05, 2008 | BenQ FP757 Monitor
Color display issues with BenQ FP757 monitor
Go to menu and try Recall all.
Also possible that panel is defective.
Samir
Oct 01, 2007 | BenQ FP757 Monitor
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
