Question about Whirlpool Heating & Cooling
Whirlpool commercial ice maker pulling out the circuit breaker after a few seconds of powering up.
    Scholar:
  • 121 Answers
The ice maker is drawing to much amperage from somewhere. Is this a free standing ice maker or in a refrigerator. If free standing then it will go through a dump cycle and dump the water out of the reservoir and refill. Then the compressor will come on and that will trip the breaker if it has a weak motor or if it is locked up. You can purchase a hard start at an appliance parts store for $20 to $30 to see if this will help the compressor before replacing it. If it is inside a refrigerator the module motor on the front of the ice maker is shorted and needs to be replaced. Again at an appliance parts store you can get for about $90 you will need the model number located inside the refrigerator.
Posted on Oct 03, 2008
Whirlpool undercounter ice maker trips breaker
If it trips the breaker either the wiring to the ice maker is shorted or the ice maker itself is shorted, do not continue to use it, there is afire hazard if you keep resetting the breaker.
Jan 16, 2017 | Whirlpool Kitchen Appliances - Others
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
My Maytag M1TXEMMWWB00 (209 cu ft) Top Freezer Refrigerator will not make ice. I checked the solenoid where the water comes in to see if it has a current and it doesn't (no juice). I looked at the owners...
The ice maker tells the water valve to open so you will not see the power until the ice maker ask for water. Does the ice maker have ice remaining in the ice slots? If not then fill with tap water and after the water freezes and ice maker cycles dropping the ice into the ice bin if it does not refill with water then you will only need to change the=> 2315576 Water Inlet Valve If the ice maker does nothing you will need to change the ice maker=> 4317943 Ice Maker Assembly You can find trouble shooting info at Appliance 911
, Thanks John Tripp
Feb 19, 2014 | Maytag M1TXEMMWW (209 cu ft) Top Freezer...
Can't figure out why when I plug in my bunn vps commercial coffee maker it immediately trips the circut breaker???
There is a couple things can cause this to happen.
Number one make sure you have nothing else added recently on that circuit, where you have had your machine plugged in. If something was added on that circuit, something that is always running like a fridge, that could be overloading the circuit, sense coffee machines use a huge amount of power at start up. If your sure nothing of that sort has changed then next is:
Number two, make sure you have cleaned the machine, you know descaling and making sure there is no restrictions. If this is good, then next is:
Number three, it appears you can have a short. The heating element going bad in the coffee maker. If the thermostat or heating element is pulling more power boost then normal because its going bad or a short this will trip the breaker. What I would first do, is run yourself a extension cord from another outlet that for sure is not on same breaker. If that breaker blows, then you know for sure it is the machine that is causing this, then we are back to the heating element or thermostat on off regulator.
What i have done is located the manual on your machine, that besides gives you a lot of information, it also gives you trouble shooting tips and schematics of the parts and wiring diagram for you machine. Here is the link to copy and paste in your browser to download the manual.
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Please if this helped you, rate my free solution and a pleasant testimony would be nice to help me and others on my efforts of helping you. Thanks So Much, Mike from Fixya.
Oct 14, 2011 | Bunn VPS Coffee Maker
HI, I have a Whirlpool Side-By-Side Refrigerator model ED25PQXW01 and the ice maker isn't working, how do I fix it??
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
The ice maker will not stop making ice even with wire handle in up position
Good day,
The wire, if inserted properly, breaks an electrical circuit, when it is in the up position.
The bad news, is the end of the wire I described is inserted into what is best described as a semi-solid state board.
This board or front end as it is often called, can be replaced, but it's cost is so close to the price of a complete ice maker that most people opt for the complete.
But you have the choice.
To replace the front end, remove the ice maker from the machine. pull the wire going into the front of the ice maker out.
Unsnap the plastic front cover, remove the wire power plug, then
remove the screws holding the front end on, and pull out.
Install in reverse order.
It, like the ice maker are very common parts, and any appliance parts house will have them in stock.
Thank you for using FixYa
Jan 16, 2010 | Whirlpool Refrigerators
The ice cube tray in the automatic ice maker overfills with water. After the ice dumps, the water for the refill overflows the tray and some goes in the dump bin.
Good day,
Sounds like a bad water valve located in the rear bottom of the machine. (not shutting down properly).
Solution is to replace the valve.
In extremely rare cases it can be a faulty ice maker.
The ice maker sends power to the water valve for 7 seconds on each cycle. If the circuit board in the ice maker malfunctions, it could cause this problem.
But again, very rare.
Dec 04, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Heating & Cooling Logo
73 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
