Question about Canon Office Equipment & Supplies
My Canon BJC 85 Printer will not print. Despite changing cartridges, printer heads, cleaning and deep cleaning the printer goes through the motions, paper passes through, the print head moves back and forth but no print appears on the page. I have also tried using the serial port as well as the usb to no avail
SOURCE: My Canon BJC-85 Bubble Jet
It is working. I just played around with it.
Posted on Oct 13, 2008
Touch2Heaven
  • 145 Answers
SOURCE: Blocked print head on a Canon BJC 85
put nozzles in still water. After 5-6 hours dry up printhead, install ink tanks and try to deep clean...
Posted on Jan 21, 2009
  • 19 Answers
SOURCE: BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Posted on Mar 13, 2010
Testimonial: "You are CORRECT. I was using a new head/ink cartridge. Replaced with another one, and problem disappeared. Thank you for taking the time to respond"
muntejaya
  • 10421 Answers
SOURCE: can i get driver for win 7 for bjc-85 printer
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay knjsdrtg
Posted on Feb 12, 2011
BJC-85 canon printer.....brand new cartridges both b&w and color. Error light chimes 8 times and won't print
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printer starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beep
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Aug 07, 2010 | Canon BJC-85 InkJet Printer
Bought used BJC-85 - feeds paper - won't print with new cartridge. Must have been dry too long. Where do I get a print head for it? Or a cleaning kit? I need it right away for a trip.
No need to change the print head. Just carry out all the maintenance tasks with the new cartridge. Make sure that you remove the thin plastic film from the ink pad. All you have to do is to click on printer/faxes in control. Click on properties in the drop down menu. Click on the maintenance and carry out each task i.e. print head cleaning, alignment, nozzles cleaning etc.
May 12, 2010 | Canon BJC 85 InkJet Printer
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
BJC 85 not printing after head replacement
I have similar problem. Print head won't print, then I clean with alcohol, and get rid of old ink inside. But then head seems to just shut down. I have several print heads and printers that have plenty of ink, but head won't work. I refuse to think the print head will break so easily. I used my BJC 85 for YEARS with no problem whatsoever, and suddenly, since last winter, I have 4 printers that have stopped printing.
I usually end up just buying another used printer on ebay until that one stops printing.
Terry tlworkroom@lycos.com
Feb 28, 2010 | Canon BJC 85 InkJet Printer
Jan 10, 2010 | Canon BJC-85 InkJet Printer
Jan 20, 2009 | Canon BJC-85 InkJet Printer
Printer error message: does not recognize cartridge
u may buy a wrong type of catridge for ur printer,the model may be slightly differ from ur printers required model so u check the catridge model which is absolute for ur printer.
Sep 03, 2008 | Canon BJC-85 InkJet Printer
Canon bjc-85 printer doesn't print anymore
Have you tried changing the green carrier? That solved my problems with no ink.
Dec 04, 2007 | Canon BJC 85 InkJet Printer
CANON BJC-85 Won't print black...
Turn on printer, press cartridge button, remove cartridge. On left side of remaining cradle, unsnap the cradle, lift up and remove. Take the cradle to your sink, wet a paper towel, and GENTLY wipe the long print head with the wet paper towel. Then run a small stream of clear cool water through the cradle, from the round pad that your cartridge rests on, until the pad looks ink-free. Dry everything with tissues and a hair dryer set on low, replace cradle in printer, replace cartridge, turn on printer, press Resume until it beeps three times, which runs the deep cleaning program, and after the procedure is finished, your printer will print as new.
Apr 14, 2007 | Canon BJC-85 InkJet Printer
62 people viewed this question
old marine
old marine
