I have a Behringer PMH660M powered mixer. After some hours sitting idle both the outputs stop working. The mixer part continues as is shown by the mixer meters continuing to operate. By turning the power off & then back on the output is restored, but after some time the cycle starts again.
  • 4,889 Answers
I would like to add up one more point.. The operating efficeincy decreases when you place the amplifier with in the range of broadcasting stations and other high frequency sources. Make sure that the amp is sufficient distance away from transmitting devices and that you are using shielded cables to avoid these complications.
Posted on Oct 03, 2008
  • 10,594 Answers
I think Mute signal activated in your power mixer. This can be due to some cold solder joints or lose connection in unit.
Need qualified service technician to check it physically.
My aim is to be able to drive a sine wave generator directly from vocals through a microphone. The set up I have planned so far goes - microphone (Behringer B-1) - Power supply (Behringer PS400) - min
  1. Yes, you need the PS400 with the B-1. Alternatively, you can connect the mic to a mixer with built-in phantom power.
  2. The PS400 shouldn't go directly to to the TA2020 because the power supply is providing a mic-level signal and the amp is looking for a line-level signal. Either add a mic preamp after the power supply, or if a mixer is used, that output can be fed to the amp.
  3. Cabling will depend on what you ultimately choose to do. But, you'll at least need a mic cable to go from the B-1 to the power supply or a mixer.
Oct 30, 2014 | Behringer b-1 single-diaphragm studio...
Behringer sx3282 Installation
You can get the manual at: http://www.behringer.com/assets/SX3282_WebBrochure.pdf
Start with 1 thing and connect the output to your amp and speakers. If that works continue to add items. When it quits you found the problem.
Jul 21, 2014 | Behringer SX3282 Eurodesk Mixer
How do I connect my behringer fbq1502 to my behringer professional mixer dx750.?
You have a sent and return http://www.behringer.com/assets/DJX750_M_EN.pdf
They explain it in the manual but the output from the mixer and between that the equalizer and the equalizer output to the speakers works great, not the tape..... they have a way lower S/n ratio and i've never heard of this solotion
Jun 19, 2014 | Behringer FBQ6200 Home Equalizer
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Where are the Amplifier inputs on a Behringer usb 2222 mixer
If you need a better answer post again with more details. You can connect an amplifier to any of the inputs assuming it has compatible output levels. In your case I am assuming you want to connect to a power amplifier, so connect to the Main Outputs.
This mixer does not drive speakers!
Nov 10, 2012 | Behringer Xenyx 2222FX 22 Input Mixer
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
142 people viewed this question
 Grubhead
Grubhead
