Hoover six 1200 Noise on drying cycle
When finished washing, and the washer goes on to the drying cycle, there is a disturbing noise from the machine, and the drum spins quickly for a second, and then slows again. It does this repeatedly through the dry cycle. Still dries well, but there doesn't seem to be a problem other than on drying.
  • 1294 Answers
SOURCE: manual
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Oct 05, 2007
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
  • 1462 Answers
SOURCE: Power is on - fuse
probably the door interlock. easy part to fit and not too pricey
Posted on Jul 10, 2008
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
Posted on Aug 04, 2008
SOURCE: Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
Posted on Sep 28, 2008
Frigidaire GLTF2940ES Front Load Washer stop spinning
Hello Kathy Murphy - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Will the drum manually rotate (when it is not in use)? If it does not, then the washer drum may not be balanced and/or possibly have a broken shock. Is the door securely latching? Supposing it is not, then the door latch assembly will need replacing. However, since it is such a complex unit, I strongly suggest contacting a professional to accurately pinpoint any potentially more serious issues like the timer, pump or control board not communicating correctly.
Jan 27, 2013 | Frigidaire GLTF2940ES Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
Oct 05, 2010 | Hoover H130E Front Load Washer
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
