Question about Plumbing
Sewer pipe im installing a new sewer pipe and wonderind how much fall it needs
  • miltonl Mar 26, 2009
    hi harvey
    i wonder if you can help me !!
    my sewer pipe is about 2 inches lower than the outlet to the public sewer what are my options ?
    Novelist:
  • 171 Answers
Hi sir simon,
I'm Harvey the Master Plumber.
Your problem is: You're installing a new sewer pipe and wonderind how much fall it needs
1/4" per foot. You can buy a plumbers torpedo level to make it easy. You'll see 4 hash marks on the tube. Center the bubble in the middle and the pipe is level, so just adjust the pipe so that the bubble is just touching the outer line and you've got 1/4". No measureing. And it only costs a few dollars.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
Sewer waste pipe replacement
plastic or croc? earthen ware? whats the material?
Jan 14, 2013 | Mountain Plumbing Products PVC Pipe Deluxe...
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
I have just remodeled a old condo with new toilets and I am getting a strong gas smell. How can I get rid of it. I am in Thailand and the building is 22 years old.
jajoy,
Did you connect the sanitary pipe stack to the sewer line that takes away the flushed effluent? Check to see that the pipe is connected, not leaking sewer gas, not plugged up with an animal carcass, and that the pipe extends through your roof three feet past the roof line (keeps smell out of house).
Nov 29, 2010 | Air Purifiers
Leaking sewer pipe
Depending on how many pipes you have connected in the run from the toilet to the concrete pipe, I would replace all of it with plastic pipe and a new soil pipe if I could find one, if not put the plastic in the soil pipe and pour a concrete patch to fix the hole. Without seeing what you have there, it is hard to say for sure. But cast iron is not used much these days and a job to fix, cut, seal, repair, most are replaced. Hope this helps.
Jun 01, 2010 | American Standard 2860.334 Enfield Two...
How do i get the collars of a ''y'' over the cut ends of the existing sewer pipe where I need to install the ''y''? I'll dig down 24'' to the existing sewer pipe but I don't think it will move or flex...
glue in a 12" piece of pipe into each end of the pipe (not the vertical).....take that total measurement and cut the existing line enough to allow it to go inbetween.......get two "no hub" or "hubless couplers......glue everything up......slide the couplers on the existing pipe....position the wye/pipe.....slide couplers over. That will have to be done in a very fast manner.
The other option is getting rubber couplers as you don't have to worry about the glue going off.
Hope this helps and good luck.
Mike
Jan 27, 2010 | Plumbing
Fowl smell in bathroom
Fowl smells related to plumbing can have several causes. Here's a few potential issues that you can check. If none of them solve the problem you may need to call a plumber.
1) Look at your pedestal sink drain connection. Is there an an elbow connecting to your drain or a P Trap? A p trap is a pipe shaped like the letter "p" (hence the name) and it prevents sewer gas from rising into the bathroom. **sometimes an apprentice plumber puts in a pedestal without a p trap because they are fairly difficult to install, and ALL fixtures need P traps. If there is no P trap, then you need to put one in. It will be a tight space, but you may be able to do it yourself.
2) Do you have a floor drain? If so, your sink will need a trap primer at the drain. Or you can pour water into the drain from time to time before it evaporates from the trap
3) If the smell is more of a sulfur type smell and it appears from running water in other places in the house, then it could also be due the type of tank you have if you are on well water
My offhand guess is that number 1 is your issue.
Without further info, those are some of my best solutions so far, but if none of these are potential solutions, then make the following tests
1) close the door to the bathroom and leave it for an hour or two. Return to the room. Do you smell sewer smell? Is it in the entire room or more concentrated in a certain area? If you don't have a floor drain and its everywhere, there could be a missing P trap from a fixture, a lose toilet flange, a cracked drain pipe
2) without running water, smell your drain. Does it have a sewer smell? Then the P trap either is not present or you need to clean the drain with a drain cleaner due to a list of reasons
3) run water. does the sewer smell increase or does one suddenly appear. Is the smell more a different odor than sewer. See if it is the water itself. If so, check other places. If they do not have the smell then you may have recently installed your sink and there is some smell related to the new valve. Then you would need to use it some more until it disappears.
Check the top list, though because I really think you're just missing a P trap
Sewer breaks below the slab, an open pipe somewhere, some issue with the water supply, are among some other issues but that depends on the test
Jun 22, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
How to Install plumbing in the basement?
A sewer ejector pump is the answer. The waster line is run into the sump basin, pumped through a checkvalve into  the sewer line that grades with gravity.  A vent pipe needs to be run also, (you can't pump out without replacing the air, it's like trying to suck air out of a bottle) If you add a high water alarm, which is a good idea. It is run off of a separate electrical breaker (insurance) to let you know if the pump isn't working before it's flood time.  The check valve makes sure, that what you pump out, stays out. Otherwise the pump will keep cycling.
Aug 27, 2008 | West Brass WestBrass Faucet Master Large...
Installing a Washer in basement
The top of the drain pipe that the washing machine drains in to should be about 3 feet off the ground. If the sewer pipe is higher than that you can either get a longer hose, or drain it into a sump with a sump pump that pumps it into the sewer pipe. If you don't have a sump, first try the longer hose and make sure it drains to a point higher than the sewer pipe (that would be the easiest) or cut a hole in your floor and put in a sump and sump pump (the most difficult).
Oct 08, 2007 | Washing Machines
Plumbing Logo
410 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
