Question about Acer TravelMate 2300 Notebook
Failled note when i open my laptop it will apear anote as (fialled to get date scheme for DC )
As been posted. I cant log in to facebook,theres anote What's your problem?
You can contact Facebook support here:
http://www.facebook.com/note.php?note_id=410099297768
Phone #'s: 650-543-4800
650-853-1300
Fax #: 650-543-4801
Sep 02, 2012 | Facebook Social Network
I have a virus on my laptop, it won't let me open anything and CA antivirus won't open either.
As you have access to anoter PC/laptopthen download and burn to disc the F-Secure rescue CD. Once done insert disc on laptop and ensure you select boot from CD.
F-Secure will download the updated virus database and scan and fix your system before windows starts.
You can get it here.
Dec 25, 2010 | Computers & Internet
PICTURE QAULITY SEEMS TO HAVE GOTTEN POORER GOT BIT DULLER AND SLIGHT GREEN TONE THROGH PICTURE BOUGHT TV 2YRS AGO
Probably a failling DC-DC invertor which powers the back light, it's the most common fault with LCD TV's check to see if there is a wear kit available.
www.lcdtvparts.co.uk is a good site for spares
Regards.
Oct 17, 2010 | Televison & Video
Battry
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | ASI CL51-15 Notebook
Nec versa 4230: What is 4 pin adapter pinout ?
It is 13.5 v dc.
When viewing the end of the cable that connects to computer with the centered notch up, upper left and lower right are positive.
Upper right is negative (per the labeling on back of ac adapter),
Mar 01, 2009 | NEC Versa LX Notebook
Audio driver installation failled
try to install again then when the window pop up that says new hardware found plsss don't click just leave and w8 for the realtek logo to apear coz it will automatically install..
Feb 02, 2009 | ASUS P5PE-VM Motherboard
How do I change my AC/DC power setings on my laptops?
note14.jpg To change the power scheme
    1. In Windows XP, click Start, then click Control Panel. The Control Panel window opens. If your Control Panel is in Category View, click Performance and Maintenance.
      - OR -
      In Windows 2000, click Start, Settings, then click Control Panel. The Control Panel window opens.
    1. Click/Double-click the Power Options or Power Management icon. The Power Options Properties dialog box opens.
    1. Click the arrow button to open the Power Schemes list, then click the power scheme you want.
      - OR -
      Set the timers, then save your custom power scheme by clicking Save As and typing a name for the scheme.
      If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
      Thanks, Joe
Nov 03, 2008 | HP Pavilion dv6000z Notebook
How do you set the image's filename to automatically include timestamp and date
Dear jeannesc:
I am assuming that you are using ZoomBrowser EX ver 5.8 which comes with the SD750's Digital Camera Solutions disc. Therefore these instruction will pertain to that version of the program.
You can rename image files using four different naming schemes:
1. Image Name + Number (e.g. Vacation_001.jpg)
2. Shooting date + Number (e.g. 20080601_001.jpg)
3. Name + Shooting date + Number OR
4. Shooting date + Name + Number
There isn't a provision for a time stamp naming convention.
To rename a group of images using one of the above naming schemes simply open ZoomBrowser and point it to the folder that contains the images you wish to rename. For this example let's assume it was your recent vacation photos.
I would utilize either Zoom or Scroll mode to view the images on the main screen. Then follow these steps:
1. Click the task panel labeled "View & Classify"
2. Next click the sub panel "Rename Multiple Files"
3. On the left hand panel click Step 1 "Select images"
[Here you can select any or all images in the folder]
4. Next click Step 2 "Specify Rename Settings"
5. Select the way you want the files to be named and enter
the appropriate settings. Note: If you wish to keep the original
file and make a copy with the new naming scheme make
sure you check "Make Copies of files"
6. Lastly click Finish and your newly renamed files will be there
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
I accidentally deleted my sound card
Hi UK2008,
you can do restore incase you use Windows XP,
1.click start-->programs-->accessories-->system tools
2.click on system restore
3.choose the back date or the same date(incase you deleted only sound driver)
4.click next and let it complete the process
5.it should restart your windows and everything should work
** incase still problem then go more backward
goodluck,takecare
May 13, 2008 | LG X-Note LM50 Notebook
Canon Power Shot A520 upload a image to the computer
Dear binghau:
The surefire way to have the date show on your pictures is to set your camera's resolution to PostCard Mode and thus record the date stamp on the picture itself. Your ZoomBrowser software, however can put the date on each of your images. I am using ZoomBrowser EX ver 5.8 as an example. If yoiur version if different it will still have similar functionality.
You may choose to do either method 2 or 4 to get the date.
To rename selected images or a group of images using one of the above naming schemes simply open ZoomBrowser and point it to the folder that contains the images you wish to rename. For this example let's assume it was your recent vacation photos.
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Apr 17, 2008 | Canon PowerShot A520 Digital Camera
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
