Question about Kenwood Car Audio & Video
When installed and turned on for the first time a lok code is presented for which i dont have. is there any way to bypass this at all? i probably have to disconnect the internal battery dont i ?
    Sergeant:
    Champion:
  • 227 Answers
Dear friend, sometimes by disconnecting the radio for a few hours will do the job, can you post the model number
caypianan@yahoo.com
Posted on Oct 03, 2008
Unit powers up but shuts down after being on for 5 minutes. Unit has auto shutdown after 1 hour feature. If that is the problem, can it be bypassed and how?...or is it a case of thermal overload? and how...
These radios often shutdown after a few minutes because it requires a code to be entered.
Is this the case with your radio?
Have you had the battery disconnected recently?
Apr 07, 2011 | Car Audio & Video
How do I bypass the factory monsoon amp on a 2001 chevy camaro?
Every time I've done an install an a Monsoon system, I've run new speaker wires. It's the easiest way to bypass the amp because I don't believe there's anyway to integrate it. You should be able to locate the constant and ignition wires in the factory harness with a multimeter and tap into those.
Hope this helps
Ray
Mar 12, 2011 | Car Audio & Video
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
I dont know the security code and when turned on it says safe
The code for your radio is usually in with the service documentation and manufacturers will put it on a card about the size of a credit card. Sometimes the code will be handwritten into one of the owners manuals so leaf through these as well to see if it is present anywhere.
If the code is not to be found in the documentation your local dealer can provide the code from their database but there is usually a charge for doing so. Ford for example charge $30 or Mercedes $60.
If you have a Ford, Fiat or Renault you can try this site which I can recommend. They can decode these types of radios directly from their serial number along with Becker units fitted to BMW, Porsche and Mercedes by request and at a much lower cost than a dealer charges.
Not all makes or radio models can be decoded this way so decoding services are limited to certain radios.
Hope this helps. Any questions just let me know. Thanks for using FixYa.
Dec 19, 2010 | Car Audio & Video
I bought a car from a car auction and it had a kenwood dnx9140 but when i turned it on it said enter security code but i dont know it because it was in vehicle that i bought , is there a bypass or default...
Probably not, you can buy security codes online, you just need the serial number off the head unit so you may need to get it out,
have a look here fore some head unit removal guides ;
www.carheadunit.co.uk
Oct 29, 2010 | Kenwood Car Audio & Video
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
I have a kenwood deck and it locked i can not use it it is a kdc-mpv6022
Good Day,
KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!
The above was pulled from:
http://forum.ecoustics.com/bbs/messages/4/134366.html
Also try:
press reset use remote right after it loads press 552222777 then track forward do this with the remote open so you can use the numbers and make sure its in the audio mode the little switch on the side. prerty simple p.s. nothing will happen on the screen so dont stop pressing the code and press track forward you can now set the code to what ever 4 dig code you want in the set up screen
Also try: bypasse code of "2222"
Hope this helps
Jul 07, 2008 | Kenwood Car Audio & Video
Need unlock code for kdc-mp825
Good Day,
Type 1
Type 2
Type 3
Also try:
Jul 05, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
16 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
