Question about SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Finding of IP for the senao 3320 ext.
We are not able to find the IP address for the device as there is no option for reset to factory settings or any physical switch to reset the device.
  • 3 Answers
Repair center, visit : http://www.gblmedia.com
Posted on May 02, 2009
Tplink 5210g not reset
A hard reset will remove all your settings, and your device will be restored to factory default settings.
Do not perform a hard reset unless you have backed up your settings or you can do the configuration again.
Directly press and hold the reset button on the rear panel with a pin for approximately 6 to 10 seconds when the device is running, then the device will be reset and reboot automatically.
Note:
1. Make sure the device is powered on before it reboots completely.
2. After the hard reset, the IP address of the device should be change to the default 192.168.1.1/192.168.0.1, and the default login username and password are both admin.
3. Ensure that the IP address of your computer is in the same IP range with the device. That means your computer should have an IP address like 192.168.1.X/192.168.0.X (X is in range of 2~253), and the subnet mask is 255.255.255.0, the default gateway should be 192.168.1.1/192.168.0.1, which is the IP address of the device
Jul 12, 2013 | Computers & Internet
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
Noy finding ip address senao wireless AP
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Jul 18, 2009 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
May 14, 2009 | EnGenius EOC-3220 (EOC3220)
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Senao USB wifi 802.11
I am afraid that I have had to make an assumption as to the precise modle that you have but the following link should be correct, it gives you the option to download drivers for the
Senau NUB362 (Ext)
http://www.senao.com/English/Default.aspx?TYPE=test.htm&PT=searchDownload1&sf1=D331&sf2=NUB-362(EXT)&sf3=&tv_TCAT_POS=0&CATNO0=D&IDX=3.2&CNT=1&CATNO1=D3
numerous drivers for different operating systems seem to be avaliable.
if I have chosen the worng type a pull down list is avaliable showing the differnt Senao product drivers avaliable.
Nov 14, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Senao 3220 - access configuration info
I do not know what you have for a DHCP server but some DHCP servers will show you what devices have been given IP addresses which you can use that information to find what address it is at now. Other than that you can use the guess and check method just going through IP addresses until the page comes up, you can use network mapping software to scan your network to find it or you can reset the access point to factory defaults where it will have the default IP address that you can then connect to and re configure it the way you want it.
Jul 06, 2008 | Computers & Internet
Senao 8610 not working
Are you saving your settings when you exit the setup screen?
Johnlgrn
Dec 29, 2007 | EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g...
SENAO wireless adapter not working
I assume you have the unit set to alocate ip addresses automatically in other words the dhcp is set to enabled in the settings. If so it maybe that the address is registering wrong, you can either click start>run> then type ipconfig /flushdns, or uninstal your wireless network card in device manager then restart the pc to automatically install it again as this will set it back to default, but remember to make sure obtain ip address automatically is enabled in the adapters properties on the tcp/ip properties.
Aug 06, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
SENAO NL-2611CB5 PLUS (NL2611CB5PLUS) Logo
339 people viewed this question
Top SENAO Computers & Internet Experts
Terry Hair
Vernon Taylor
Are you a SENAO Computer and Internet Expert? Answer questions, earn points and help others
