Question about ASUS P4GE-MX Motherboard
Bios system error and keyboard no detecting.....
What is the problems betwen motherboard and bios...why give this massege in the monitor screen?
    Genius:
  • ASUS Master
  • 1,250 Answers
Put some other key board reset your the bios of *********** board
Posted on Oct 03, 2008
What is bios?
A BIOS (Basic Input/Output System) is an electronic set of instructions that a computer uses to successfully start operating. The BIOS is located on a chip inside of the computer and is designed in a way that protects it from disk failure.
A main function of the BIOS is to give instructions for the power-on self test (POST). This self test ensures that the computer has all of the necessary parts and functionality needed to successfully start itself, such as use of memory, a keyboard and other parts. If errors are detected during the test, the BIOS instructs the computer to give a code that reveals the problem. Error codes are typically a series of beeps heard shortly after startup.
Oct 02, 2010 | Intel Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Keyboard failure at boot cannot use F2, F8 or F12 keys
http://www.youtube.com/watch?v=9MlWAJ0Y0Yg
watch it and bam solved
Aug 14, 2009 | Dell Dimension E521 PC Desktop
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Clarification about my foxconn bios checksum error
try to change cmos battery...
or
flash BIOS
download bios from bellow link
and pls refer the manual.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000004
thnaks
if ur problem solve so pls rate me..
bye
Mar 05, 2009 | Foxconn 661FX4MR-ES Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
EHCI controller not detected
try installing the software drivers for keyboard and mouse.....then see whether keyboard and mouse is working...if the problem persists.....then the problem is in motherboard.....that you have to give it to repair shop....so that you can identify the problem.....i am a software engineer.....and i have experience in these areas....thats why suggesting you this idea....try this....it will work 100%.....
Sep 20, 2008 | ASUS P5SD2-X Motherboard
Dimension c521 computer gives a post error, floppy drive 0 error and keyboard error
The compute post tests the computer, insuring that it meets the necessary system requirements and that all hardware working properly before starting the remainder of the boot process.
1 Short Beep, Normal POST, computer is okay. No problem. 2 Short Beep, POST error....floppy drive 0 error and keyboard error........This can happen because there is something wrong with your floppy drive, something is causing your computer not to detect it or that you simply don't have one.
Check your floppy cables and connections first to ensure that they are connected properly, if they are then you may have a burned out controller on your motherboard, a bad floppy cable or drive, or your motherboard may be faulty. If you don't have one you can disable the message in your computers BIOS. To get to the BIOS screen, during boot up at the bottom of the screen it will say something like "press F2 for setup" or something along those lines. That will take you to the BIOS screen. In the settings there should be options like first boot device, second boot device, and so on... change the one that say 3.5 floppy to something else such as your CD rom.That will get rid of that message.
Keyboard error or no keyboard present shows up when your computer can't find your keyboard or there is something wrong with it. Replace with new keyboard. Thank you
Sep 06, 2008 | Computers & Internet
Tower broken
This is a stupid error. Check the motherboard inside and see if anything has gotten unplugged. There is no way for a chipset to break or come off without you doing it. Is this a DOS start up screen or a windows screen? The tech that you talked to is an idiot. If this is a windows error, it is some software installed that is giving this error. May be a motherboard monitor. If you have a motherboard monitor and everything is running cool then it is nothing. This can be checked in the BIOS; hit DEL or and F key when it starts to check your temps.
You can buy any computer and it will work with any keyboard or mouse, monitor,speaker, or anything else that will connect as long as it is not software related with the operating system. The operating system will have to support the drivers for a printer, scanner or something like that.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
ASUS P4GE-MX Motherboard Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
