Question about Compaq Presario M2000 Notebook
Fine horizontal lines on the screen
Hi, ive noticed that my compaq presario notebook had fine horizontal lines on the task bar of my notebook...starting in turnig on and shut down my notebook, these fine lines also can i fix it???tnx
  • 1 more comment
  • chrisbayot Oct 28, 2008
    my compaq presario x6110us has horizontal lines from top to bottom . even while im using other programs it stays the same. pls help
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Please clarify by restating the problem for me in this manner.
    Do the lines appear on screen all the time and do they extend partially across the screen or begin and stop randomly on the same row of pixels?
  • Glenn Rogers
    Are you online now?
  • Compaq Master
  • 1,250 Answers
This may be due to fault in your display panel, check it by some hardware professional nearest to you
Posted on Oct 03, 2008
My recently purchased used Compaq Presario V2665US notebook has a horizontal white line at the bottom of the screen below the windows Taskbar. The line actually cuts into the bottom of the Taskbar a...
The line is there because the connections to those pixels are bad so they end up uncommanded - fully open all the time. To fix it you will have to dismantle the lid and reseat the connectors to the LCD panel.
Dec 11, 2010 | Compaq Presario V2665us Notebook
Horizontal lines on screen
Increase screen refresh rate. It's at Display properties.
Nov 29, 2009 | HP Compaq Presario CQ50-210US Notebook
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
FS050UA , COMPAQ PRESARIO NOTEBOOK PC CQ50-210US the screen has lines and a black spot
Turn on the notebook and press F10 to get into BIOS screen. Even if the lines and the black spot appears then the issue is with the internal hardware of the notebook.
To check further connect an external monitor to the notebook and press Fn and F4 keys on the keyboard to get the display on external monitor. If the external monitor display is fine then the issue is with the LCD screen or else the issue is with the Video card of the notebook.
Jul 31, 2009 | HP Compaq Presario CQ50-210US Notebook
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
I have a compaq presario 2500 notebook. when i start it up, there are small, horizontal lines running across the monitor that break up the screen into horizontal blocks. occasionally, this ceases, but...
I had the same problem and after partial dis-assembly and reseating all the LCD cables, including the one behind the LCD screen itself the problem was resolved
Mar 04, 2009 | Compaq Presario 2100U Notebook
Problems booting up--no access to toolbars, etc. on XP
To resolve this issue, simple trick is, when it stands at the wallpaper without Start menu and Task bar, Press Alt + Ctrl + Del keys
Then select TaskManager.
In the Task manager, select Process Tab.
Under that select Windows Explorer process and select End
Again click on File menu in the same Window and select New Task.
Type Explorer.exe in the blank and click okay--OK
That should bring the complete screen.
Aug 04, 2008 | HP Compaq Presario V2000 Notebook
Red line on my screen
You need to replace screen not other choose.
Apr 27, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
207 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
