Question about Packard Bell Computers & Internet
Computer will not turn on. it sounds like it is starting up, then lets off a series of 3 or so beeps then shuts down again
    Problem Solver:
  • 9 Answers
1- chek your cabels current source if no proplem
2- chek your power supplay if no proplem
3- chek your computer switch if no proplem
4- put up your computer battary
clear cmose by gumber on *********** board
chek again
unplag you main ram tray again
if no change caps on *********** board
Posted on Oct 03, 2008
    Genius:
  • Packard Bell Master
  • 1,250 Answers
Check the cpu fan,
When it starts it beeps 3 times and then shuts down
It sounds like it might have overheated, first let it cool down for a little while then and try again. If it starts working again, get compressed air and clean out the PS3, and possibly get an external fan to stop so this doesn't happen again. If the PS3 still does the 3 beeps try putting the PS3 in recovery mode by going to the recovery menu. Which can be done by doing the following.
  • Turn off the PS3
  • Hold the power button down; the system should turn on and turn itself off.
  • Once its turned it self back off press the power button intill you hear to beeps
  • After you hear the beeps let go of the power button
  • You will told to plug your controller in and press the PS button
  • Then the recovery menu will pop up
If the PS3 still doesn't turn on it be dead and need to be replaced. Best of luck!
Jul 18, 2010 | Sony Video Game Consoles & Games
Turns on, then shuts down before anything shows on monitor
Hi m5mm, what kind of Operating system are you using?
Jan 03, 2008 | Gateway GT4022 PC Desktop
It started with the computer not getting power weeks ago but you could play the cord it would kick on no big deal. I figured I needed a new cord. Then yesterday it started turning itself off. If it sat...
Your power jack is bad. The cable and DC jack are a one piece cable that can be unplugged from the motherboard and replaced. They are available on EBay for around 30 bucks or less and takes approx. 30 minutes to change out.
Jun 27, 2010 | HP Pavilion dv7-1132nr Notebook PC
My Dell Inspiron 1521 has had a battery problem for a couple of weeks but just taking the battery out and only using the adapter worked just fine. One night the computer shut itself down twice. The next...
Try running the diagnostics on the computer. You may need to repeat some of the steps that you have already done to initiate the same.
1. Remove the battery and the Ac adapter from the system
2. Press the power button for 10 seconds
3. Reinsert the battery and connect the Ac adapter
4. While holding down the FN key on the keyboard press the power button.
If the system beeps in a series on 3-3-3 or 3-3-4 the system is ok and there could be a problem with the screen.
If the system beeps in some other code . revert to the post and we would let you know where the problem is .
Thanks for using fixya
proton
May 11, 2010 | Dell Inspiron 1521 Notebook
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Jan 28, 2009 | Kenmore 73952 Gas Dryer
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
My computer crashed and now the monitor goes into power save mode
You said that you hear a series of beeps, if you hear this kind of sounds maybe there is a loose connection from the CPU. Try to remove the Memory and put it back again.
Mon =)
Nov 15, 2007 | IBM IntelliStation M Pro 6219 PC Desktop
Computers & Internet Logo
105 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
