Question about HP Computers & Internet
Will battery stop your harddrive/ - HP Computers & Internet
    Problem Solver:
  • 9 Answers
No but change battery so its effect on softwere like antivirous
Posted on Oct 03, 2008
TECRA M2-S730 wont boot from cd or harddrive what is wrong?
The coin cell battery on the motherboard will stop it from booting if it's dead because the time and date is missing.
Sep 23, 2014 | Toshiba Tecra M2-S730 Notebook
Hard drive door unscrewed and hard drive was hanging... Now this screen?
This is a network PXE boot screen. This is usually the last boot device it will try if it doesn't detect a HDD or cd/dvd drive with bootable media. You should be able to see a hard drive in bios, if not replce it and re-install your operating system.
Dec 25, 2012 | Computers & Internet
How do you remove a hard drive from dell m 6400
Dell Support > Precision M6400 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/wsm6400/en/sm/index.htm
Left-click on Harddrive in the list.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) Suggest lay a soft Static free cloth on a table. Lay the laptop upside down on the table, Battery Compartment facing you.
3) Remove the Base Assembly Cover,
http://support.dell.com/support/edocs/systems/wsm6400/en/sm/base.htm#wp1184372
This model can use Two harddrives.
A Primary harddrive, and a Secondary harddrive.
Removal and installation for both is shown in the Harddrive listing.
Regards,
joecoolvette
Apr 25, 2012 | Dell Computers & Internet
Hp notebook G61 primary internal battery replacement
1) Remove ALL power. Remove the AC adapter (Charger) and Battery. (Main battery)
2) Lay a soft static free cloth on a table, lay the laptop upside down on it, Battery Compartment facing AWAY from you.
3) Remove the Harddrive Bay Cover.
This is the large rectangular cover nearest you.
Two Philips head screws are loosened all the way, on the Right side of the cover. Then the right side of the cover is lifted up. (The Left side has plastic tabs. Swing the cover up, and out )
4) Three Philips head screws hold the Harddrive Caddy in. One on the right side, two on the left.
Remove the screws.
Grasp the Mylar tab on the Harddrive Caddy, and pull to the right.
This disengages the Harddrive from the interface of the motherboard.
Lift the Harddrive up, and out.
5) The RTC Battery is under the Harddrive Caddy.
Real Time Clock Battery.
Plugs in with a white connector, on the end of it's Black, and Red wires.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2012 | Computers & Internet
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Pavilion dv4 1431us how to remove the hard drive. Don't know which section is the hard drive screw to unscrew.
The Battery Compartment Cover is to the outside.
(By the way. Have all power sources removed from the laptop. The AC adapter {Charger}, and the Battery)
Laptop upside down, face the Battery Compartment to the top.
The long middle cover in the middle, under the Battery Compartment Cover is the Harddrive Compartment Cover.
On the Left side of the Harddrive Compartment Cover are two screws to remove. One in each outside corner.
After the screws are removed, lift up on the Left side to remove the cover.
(They may just loosen to a loosened state, and not actually remove)
The Harddrive Compartment Cover is 'hinged' on the right side, with a couple of plastic tabs coming from the cover itself. After it is tilted up far enough so that these tabs will come free from the slots they're in, the cover can be removed.
There are 3 screws which hold the Harddrive Caddy in place. (The Harddrive is mounted to a sheet metal Caddy, which goes across the top of the Harddrive, and down each side)
The first screw is in the Middle to the Left outside.
The other two screws are on the Right, and are on the corners.
After removing the screws you will see a Black strip of cloth/plastic coming from the Left side of the Harddrive/Caddy combo.
The Harddrive is eased up slightly on the Left side, and pulled to the Left side with the strip of cloth/plastic.
(On the Right side of the Harddrive is the interface. The pins that come out of the Harddrive. These pins insert into a female socket in the laptop)
The Caddy around the Harddrive is mounted to the Harddrive with 4 screws.
Two on EACH side.
Holding the Harddrive in the direction it came out of the laptop, (Interface pins to the Right), look at the mounting screw on the Right side.
The one that goes through the sheet metal Caddy, and fastens it to the Harddrive.
Now look at the same screw on the Left side. It goes through a tab.
Remove these screws, and DON'T loose them, or mix them up with the other screws.
(Use a multi-compartment container. You can use a clean egg carton in a pinch)
Remove the screws from the other side.
Install the new harddrive in the Caddy, then install the Harddrive/Caddy assembly in the laptop.
DO NOT overtighten the screws.
Regards,
joecoolvette
Oct 18, 2010 | Computers & Internet
When I start my laptop it makes loud beeps, then it says no hard drive detected... Whats wrong?
The harddrive is not working, or is not connected properly.
Shut the laptop down.
Remove the battery.
Turn the laptop upside down.
Remove the screws in order to remove the harddrive cap. (The acer laptops have small signs on the caps. The cap that has the little circe-cylinder signs on it, should unlock the harddrive)
Remove the screws keeping the harddrive in place.
Remove the harddrive.
Clean the connectors on both the harddrove as the motherboard.
Reconnect the harddrive and turn the laptop on.
If it is working, turn it off, and fit all the screws in again.
If it is not working, then you probably have to change the harddrive. You could also connect the harddrive to another computer, to make sure if it is broken.
Sep 17, 2010 | Acer Aspire 5100 Notebook
Hardrive not working
Try the harddrive in an external case. If that dosent work the board on the drive is fried, and youll have to find an exact harddrive and transfer the board.
Jan 11, 2009 | CybertronPC AMD Sempron 2400+/ 128MB DDR...
Computer gateway 700 xl
battery to plug switch is not set to except power to plug so battery can charge right now it still thinks its on the battery so no juice no comp
May 07, 2008 | Computers & Internet
Palm Lifedrive failure
I found this on the Palm website about the frozen Palm Logo screen
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Dec 03, 2007 | Palm LifeDrive Handheld
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
