Question about Nokia 6300 Cellular Phone
Wall paper image disappers when phone is turn off and back on
Hi i've got a 6300 black i use a picture of my kids as wall paper and yes i have made sure its been activated. once i turn off my phone then back on again its not there and have to reapply it again very annoying. i know 2 ppl who have a 6300 silver and it doesnt happen on there phone. asked the place of purchase and they said to do a software update which i have done from 6.01 to 6.6 it hasnt fixed the problem. any how the company i purchased it from replaced with another pone but same thing happens.
How can i fix this.
Please Help
Thank you
Hayley
  • assaad_1 Oct 03, 2008
    Thanx for ur quick reply...but no it gives me a blank screen :(
  • Anonymous Mar 14, 2009
    I have the same problem - but it is only doing it since I changed my memory card... not sure if this is significant but I can't seem to solve it. Help please!!
    Sergeant:
  • 196 Answers
Try saving the picture into phone storage rather than SD storage then applying it as wallpaper.. hope it helps (I dont have that phone but have ran accross same problem in the past with other phones)
Posted on Oct 03, 2008
Kid play with my nokia 6300. The security code is needed to unlock phone. Try all the normal nokia code 12345 the phone still won't unlock. I'm noy sure what code the kid press for the security code? My...
Hi
The default Security code is 12345.
If you changed it and forgot the security code please contacts your device dealer. They will provide you the default security code so that you can use your phone.
This security lock prevents thieves from being able to make use of stolen handsets that is why it can only be unlocked by authorized device dealers.
Thank You
Dec 07, 2010 | Nokia 6300 Cellular Phone
How to activate gprs on nokia 6300
here is a simple instruction for you to activate your nokia 6300 phone:
1. Go to Menu > Settings > Configuration
2. Choose Personal configuration settings
3. Press Options
4. Select Add new and Access point
5. Fill in a Account name
6. Select Access point settings
7. Set Data bearer to GPRS
8. Select Bearer settings
9. Enter GPRS access point (APN);check your settings.
10. Set Authentication type to Normal
11. Enter User name and Password if requested
12. Back * 3
13. Choose Options and Activate
14. Go Back
15. Set Preferred access point to the access point you just made.
16. Set Default configuration settings to Personal configuration.
17. Select Activate default in all applications and Yes
Nov 08, 2010 | Nokia 6300 Cell Phone
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
How can i browse internet in 6300 because evry time i try always ask for packet data connection.
Hi, Welcome to FixYa.
Before using gprs you have to install setting for it.
If you call your network provider there you can activate GPRS for your profile(First thing to do).
Also ask them to send you the setting for GPRS for your particular model of mobile. It might take some time to get it activated. After installing the settings goto Settings > Configuration > Activate Default in all apps.
After this switch off your phone and switch on. Now it should work fine.
Our site need your feed back for improvement.
If the post helped you, please select 'YES'
Jul 09, 2009 | Nokia 6300 Cellular Phone
During making pictures with nokia6300 the there is
i had faced this problem once. i tried restorin it to its factory setting and it workd.... u mit wanna try it.
Apr 07, 2009 | Nokia 6300 Cellular Phone
Hi, when i turn my nokia 6300 phone on, as it is coming on, the message symbol is flashing with a yellow arrow, the phone then goes to a blank white screen then reloads 2 or 3 times then switches off...
try a factory reset on the phone, if this doesnt work make sure all your messages are deleted and also try installing the latest software on the phone, this can be done from www.nokia.com
Jan 02, 2009 | Nokia 6300 Cellular Phone
Wall Paper in full screen
Hi, I am using Nokia N73 music edition. I want to know Can we have Wall papers to come as full screen when applied as the wall papers, instead of what it comes as i.e, in standard size.
Jun 02, 2008 | Nokia N73 Cellular Phone
Security Mastercode: 5136042766 Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Apr 06, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Blank screen?
Baby-dribble + Phone = Dead Phone If your phone was exposed to baby-dribble, your kid might have killed your Phone. Take it to your local Service-Center and have them take a look at it. Let them decide if the phone could be repaired or might be up for early replacement. Normal warranty-conditions might not cover the damage if its "moisture-damage".
Oct 01, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
