Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer
FO2 FAULT
  • 5,911 Answers
"F02" is a Long Drain error. You need to check the drain pump and/or drain hoses for obstructions. The following link explains how:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you clean out the drain pump and the problem reoccurs, the drain pump may be damaged. It does not take much to cause irrepairable damage to the pump impeller and motor. A replacement (if required) can be purchased at searspartsdirect.com. Just type in your COMPLETE model number and the pump will be located under the "Pump and Motor Parts" heading as item number 10 (part #8181684). The next link gives step-by-step instructions on how to replace it:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Some of the steps may be a repeat. I hope you find this information helpful and you can resolve this without replacing any parts. If you do need parts, however, you have all the information you need. Let me know if you require additional assistance.
Posted on Oct 04, 2008
Whirlpool fo2 code
You may just have some coins clogging the pump. Better take it out side to take pump off. But is is easy.
Jan 02, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How can fix f 02
whirlpool duet f02 codeHow to fix fo2 fault code on a whirlpool duet front load washing machine, The whirlpool duet is one of the machines that have a main computer control that operate and monitor the functions of the machine,
This control is usually mounted behind the front panel,sometimes at the back or to the side, it also has a speed control board that is mounted on the bottom usually at the right side.
Whenever a problem accur there is a fault code displayed on the machine, there is a technician sheet with the fault codes on the machine, the technician can use this guide to go directly to the problem,
This f02 code mean there is a problem with the drain, there is a drain filter that sometimes get clogged with lint and other things,
Removing the kick plate and removing the drain access on the pump will reveal the drain filter, use a small bucket, and towels to catch the water that will be in the pump
Nov 26, 2012 | Whirlpool duet Washing Machines
Won't drain error code fo2
There is something stuck in your drain pump
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model # GHW9400PL2 solution for the FO2 error indicator
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing a code fo2
clean your pump
take the bottom panel off
untwist the filter
make sure you have lots of towels to clean the water thats going to come out.
this should solve your f02
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fo2 on screen
your pump is jammed clean or, replace
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Dec 23, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
