Question about Hobart Dishwashers
I have a hobart lx-g model which i purchased used a month ago. At the start everything worked great...then when ever i would push the "off" button it would shut down and restart by iteself... lately i've been getting lots of error msg's (one was E4...) and now it overflows all the time, its as if it's gone banana's... what do I need to do to fix my problems (chane the cpu???)
  • minask Oct 03, 2008
    Also, it overflows when its says fill... (while the temperature go sky hi (190f) and doesnt go in the wash mode...
  • minask Oct 14, 2008
    the machine doesnt go on the wash mode...keeps on filling up always
    Brigadier General:
  • 6,966 Answers
Initially would suggest to check that the power supply requirements are satisfied. You might also need to check the breakers. Depending on the exact model number, the AC supply can be as shown below:
If the above checks out OK, then it could be as you have suspected, the controller is messed up, more specifically the firmware or related electronics. You could of course try a reset by unplugging from the mains or switching off the appropriate breakers for say half an hour.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 14, 2008
    Genius:
  • 1,447 Answers
F the dishwasher's water flow doesn't automatically shut off, the float switch is faulty, the timer is stuck on "Fill," or the water inlet valve is stuck open. To test the float switch, you'll need an inexpensive volt-ohm meter (or multi-tester).
1) Unplug the dishwasher.
2) Reach into the cabinet, and lift the dome-shaped plastic float switch. If it doesn't lift, remove the plastic top from the stem, scrub the stem clean, and then replace the dome. If it moves up and down freely, go on to Step 3.
3) Note which wires are attached to the float switch's terminals, and, using small pieces of tape, label them for later reference.
4) Set the volt-ohm meter's dial to Rx100 and touch the two probes to the terminals. When you lift the float, the tester's needle should show an infinity reading, and, when you let the float drop, the needle should show 0.
If it doesn't, the switch is broken and will need replacement. Unscrew it from the tub, and replace it.
Hope this helps
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Oct 15, 2008
    f
    2)
    go on to Step 3.
    3)
    4)
    show 0.
    Hope this helps
    President:
  • 1,952 Answers
Dish washer fill with water when filled pump turns on10 sec if door opened during fill cycle fill will stop after door is closed the process where is continue stop
Posted on Oct 09, 2008
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Oct 09, 2008
    machine initiates a wash and rinse cycle if door is open wash cycle cycle will restart from beginning when door is closed
    mohammed marika thambi Oct 14, 2008
    Press WASH. WASH lit and sump Machine initiates a wash and rinse cycle.
    (Before you press WASH, temperature displayed
    you can change the cycle during wash cycle. If door is opened during wash cycle, cycle
    selection if desired. See will restart from beginning when door is
    READY MODE below.) closed.
    RINSE lit and incoming If door is opened during drain or rinse cycle,
    water temperature cycle will continue at point where door was
    displayed during rinse opened upon closing door.
    cycle.
    If OFF is pressed during the wash/rinse
    cycle, the machine will drain and shut down.
    FILL displayed when Dishwasher fills with water; detergent is
    machine is filling. added automatically. When filled, pump
    turns on for 10 seconds.
    WAIT displayed when If WASH is pressed during a fill cycle, a wash
    booster is preheating. cycle will begin at the end of the fill cycle.
    This preheat could take
    up to 8 minutes. If door is opened during a fill cycle, the fill
    will stop. After door is closed, the process
    continues where it stopped.
    If beeper sounds and machine will not fill,
    turn circuit breaker off, then on, and try
    again. If problem persists, contact your
    local Hobart Service Office.
    Genius:
  • 1,689 Answers
Here is what i got from Hobart...
Machine won't fill or does not fill completely.
(Display shows E0, E2, E3, working.
or E4. Machine will not 4. Drain valve open — turn machine OFF to drain machine, then
run.)
1. Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean. (Refer to Cleaning, page 12.)
3. No water pressure — main water supply valves may not be ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem contact Service.
5. Delime machine.
hope this helps out. if you have other questions just let me know
Posted on Oct 03, 2008
Purchased a great world model swe071 electric fireplace. How do you control the feature to make the flame colors change automatically without using the remote every few minutes. Lost manual
I bought a great world ltd swe067b electric fireplace ... - Fixya
www.fixya.com/.../t25420081-bought_great_world_ltd_swe067b_electri...
Feb 12, 2015 - i bought a great world ltd swe067b electric fireplace a couple of months ago.it wont ... Purchased a great world model swe071 electric fireplace. Howdo you control the feature to make the flame colors change automatically ..
Oct 25, 2015 | World Heating & Cooling
Graphices no tworking
Most of those games are dependable of RAM's and Windows XP are outdated since ten years ago, Call of Duty is not duable in less then Windows Vista enviroment.
graphic cards name and model?
have all the DirectX files updated?
have at least 4 gigs of RAM?
Mar 23, 2012 | ASUS P5G41CM LX Motherboard
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Bought a brand new Williams wall heater a month ago "converted" for propane. It worked great for aprox a month now it wont come on. The piliot is lit but just wont come on?
check thurmostat. check low voltage. check limit switch there may be several.limits should be closed. I usually push re set first, if there is a click,then switch was open.limits trip when they get too hot.is this ventless? is the vent o-k?
Dec 23, 2010 | Heating & Cooling
I have same problem, I bought this phone 6 month ago.
You will need to re-pair your phone with the earpiece. The best option is to contact your local cellular rep and get them to assist or go to the store where you purchased the earpiece.
Jul 15, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Hobart LX 30H shuts off and turns back on by itself
Hello Jon,
I work in the product service department for Hobart Corp. and work mainly with the Hobart dishwashers. The most common problem with what you have going on is a faulty keypad on the front of the unit. This is the component with the actual on/off/wash buttons on it. If the problem is very frequent, then you could contact your local Hobart service office and they could come out and troubleshoot the problem to be certain that this is the faulty part before just buying a part and hoping that it works. If you would like to discuss this a bit further or need assistance as to a contact for your local Hobart office, you can contact us at 937-332-2525, and press option #2.
Have a great day!
Jim
Nov 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Dishwashers Logo
277 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
