Question about Acer TravelMate 341T Notebook
Driver acer travelmate 341T
The resolution of the notebook anly 800x600. If i change to 1024x768 the page too big and not to fit the screen. i've already installed windows xp.
  • Vince Patron May 11, 2010
    Hi Leonardo, unfortunately, there's nothing you can really do because the native resolution of your screen is 800x600. You cannot really use a higher resolution.
    Other than using an external monitor, make sure your font size in your Windows desktop is set to the smallest (I think it's the Normal setting). You can try to see if anyone makes smaller fonts for the desktop but I don't know of any company.
    -Vince
How to center my display in acer travelmate 5720
If your display is not centered try adjusting your screen resolution. Click Start/Control Panel and look for Display or Appearance and Personalization. Open them to open the display properties and click the settings tab for screen resolution. Set your resolution up higher. The higher the resolution, the smaller the icons, thus the more fits on the screen. Normal resolution is about 1024x768.
May 29, 2012 | Acer TravelMate 5730-6204 Notebook
WHAT IS THE NATIVE SCREEN RESOLUTION FOR MY ACER ASPIRE X3200 ?
This depends on the monitor you have. A default resolution for a computer with no video drivers is 800x600
May 03, 2011 | Acer Aspire X3200 PC Desktop
Black border around screen
Have you checked to see that you've set the correct resolution for your desktop?
The specifications say that the laptop's display can show 1024x768 pixels.
http://www.toshiba-europe.com/computers/products/notebooks/tecra9000/index.htm
Set it to that first. Anywhere below that resolution (for example 800x600) may be causing black borders on your screen.
Hope this helps!
-BuzzPuppy
Apr 30, 2011 | Toshiba Tecra T9000 Notebook
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
I am trying to upgrade a TravelMate 4010 from XP to Windows 7. Everything except the video is working just fine but I can't get anything but a Standard VGA video driver so the max resolution is 1024x768...
Try the manufacturer of your graphics card for an updated driver. If they don't do one you could try a vista one and if that doesn't work try installing it as an admin in compatibility mode.
Jan 29, 2010 | Acer TravelMate 4010 Notebook
I have a Dell inspiron 1011 netbook. The problem
Sounds like your screen resolution it way to low. Right click on an empty spot on the desktop and go to properties in the drop down menu. Then select the settings tab and raise your resolution to at least 800x600 32bit. 1024x768 32bit may be better. Good Luck
Nov 23, 2009 | Dell Inspiron 1000 Notebook
Graphics card issues
if you have a wide screen laptop the picture format is 16x9 in stead of 4x3 as the old models.
you can try to change the screen resolution to something like 800x600 1024x768 this are standar 4.3 formats. after you can run the video application and see if it shows you a full screen picture. if you need more info contact me
Oct 07, 2009 | Acer Aspire 9300 Notebook
My page is coming out to big when i email document
Good day sir/maam, try set up your screen resolution to a higher one. if you are in 800x600 try 1024x768. if still won't work, install your dell video driver.
Sep 14, 2009 | Dell Inspiron 531s Desktop Computer
Laptop keeps reverting to 800x600 resolution
if you don't need the connection to the projector...remove any drivers or settings related with it ...the problem is that your settings are overwritten by that programs or drivers that you used..
in the worse case reinstall
Jun 16, 2009 | Computers & Internet
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Aug 05, 2008 | Computers & Internet
Acer TravelMate 341T Notebook Logo
308 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
