Question about Canon IXUS V2 Digital Camera
Lens error canon IXUS 70 LCD shows lens error,restart the camera.
  • jinjerjules Nov 03, 2008
    Bought for Christmas 07. Lens is stuck out and won't retract. Says "lens error restart camera" and I would LOVE to restart the camera but nothing is working on the camera at all. Have read numerous reviews stating that Canon won't fix the camera if it looks like it's been mistreated which undoubtedly they will same mine does (though hasn't been, just normal wear and tear of a year old camera). Don't even know whether to bother to send it to them. Shops quote £100+ to fix, which makes it just as worthwhile purchasing a new camera. Anyone know how to take the camera apart?! Or have any suggestions!?
This worked for my ixus70:
when you turn the power on, bend the camera with our hands - like twisting it a bit holding on opposite corners. it worked for me, the lens retracted, but it was giving strange noises a long time before, and some time after it died - i now can't use my ixus at all, shows the infamous message "lens error, restart camera".
Posted on Mar 12, 2009
  • 48 Answers
Hello
No simple fix for this one, sounds like lens block is faulty and probably need to be replaced.
Suggest you contact a local service center for pricing.
Posted on Oct 03, 2008
    Master:
  • 848 Answers
Press the power button on and hold it down while extending and twisting the zoom lens......
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • 420 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I need to restart my camara.
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
Dec 15, 2009 | Canon Cameras
Oct 08, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
How to fix digital camera canon ixus 70 'lens error restart camera'?
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Sep 02, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon ixux
try newer batteries 1st see online if ther is firmware update for your cannon.com model camera try those 1st thx nick
Oct 06, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
RE: Canon solution
It is most probably that your hand was in the way when the lens is trying to come out.
Try restarting and make sure no obstructions are in the way of the lens.
Sep 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon IXUS V2 Digital Camera Logo
493 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
