5.1 surround sound
I installed the home theatre system - but I dont think the audio setup is correct.
When I play music it seems to lack bass... very much....
It has the option where I can adjust each speaker (front left; front right; centre; subwoofer etc) with the distance and decibels volume -6 to 6 db...
What should it be?
  • Anonymous Mar 01, 2009
    just tried it myself and the bass is barely pulsing. the two separate speakers work well, but the main bass itself is lacking a tremendous amount of sound.
    Scholar:
  • 125 Answers
Here is how you fix it. Its really easy actually take a look at your Subwoofer 99% of the time you can control two controls for your bass somewhere around the Subwoofer. If you raise the volume of your Subwoofer you'll get more bass. Try it and let me know how this works out for you alright.
Posted on Oct 03, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Panasonic SA-HT878 Home Theatre want the tv to play through the surround system no matter if tv on sat dvd wifi etc please help
if your tv has an optical audio output, then hook that up to the sound system. This will put all tv audio through there instead of the tv speakers. You may have to enable that audio jack in the tv's setup menu.
Apr 23, 2014 | Audio Players & Recorders
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
CANNOT WATCH iPOD mUSIC vIDEO on Panasonic SC-PT865
Maybe because is only read audio, like Photos and mp3 audio only, expecially if read format llike "High Mat" to read photos and music, try to go to instructions manual and see the format what your dvd read.
Jan 11, 2009 | Panasonic Home Theater System System
Not playing voice but playing music/surround
sounds like you may have a dodgy scart lead.check that none of the pins are loose/damaged. Also check the sound settings on the tv, it may have reset itself to the default sound setting. Or it might just be the audio settings on your dvd player have been adjusted,almost all dvd movies have there own audio adjustments.
Jan 13, 2008 | Audio Players & Recorders
215 people viewed this question
 Grubhead
Grubhead
