Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV arcing internal high voltage tower help
Our RCA HD52W59 HDTV has started making a sparking noise. got more frequent last night. Pulled lower back cover and saw arc spots as Black wire went around it to board ext to the HV Tower. relocated Black wire away from tower and put split plastic wire loom tubing over it and used a piece of rubber to wrap around tower to add insulation to it.
Now TV makes same arcing noise but you can't see it and wont give a picture before it powers down itself after several tries on its own to restart.
Can I just buy this board with the HV tower on it? It has 2 red insulated wires coming off the top center and down lower (stepped down from the top of the tower) off the side of this tower. I think it is a HV tower.
Help please its only 2.5 yrs old. this thing was wonder full before, is it junk now?
Thanks,
Dan
  • 4 more comments
  • insltrcr Oct 03, 2008
    Is the "chassi" as you say the chassis number? If so where do I find it?
    I saw numbers on the board and I can get those for you. Is chassis number on the S/N tag?
    dan
    Chassis is ITC222 from the tag on the back.
    Dan
    Chassis is ITC222.
    Dan
    No assistance found on those two sites. Any help would be appreciated.
    Dan
  • insltrcr Oct 04, 2008
    Ok found my reciept and it is only 19 months old.
    Any help is appreciated.
    dan
  • chauvette Oct 09, 2008
    Mine just started doing this today! It's arcing on top outside of what looks like a transformer inside the small back panel.
  • 905 Answers
The high voltage pack or FLYBACK TRANSFORMER may have a ground issue , the wire may be dammaged , the board may need some resoldering
Posted on Oct 07, 2008
    President:
  • 4,402 Answers
Http://www.riddledtv.com/repair/RCA.html
http://serviceman.site88.net/index_files/Projection.htm
try these sites see if they help u
need to know chassi
Posted on Oct 03, 2008
My RCA HD52W59 problem
set is prone to two problems: high voltage splitter at front of set behind speaker grill arcs-------also set does have parts on HV board that do the same thing---HV transformer feeds voltage to the splitter.
Jun 07, 2012 | RCA HD52W59 HDTV Projection Television
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
I hane an RCA HD52W59 rear projection TV. When
The FBT,the flyback transformer is dead.Some the transitors in the deflection board is dead also.U know how to used a Ohm meter,and know soldering.Tries wesite like Tv repair World.com will help u to find the cause and replacement parts.
Apr 23, 2010 | RCA HD52W59 HDTV Projection Television
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
Im fixing a rca hd52w59 itc 222a and i found the flyback making an arc of purple energy and the tv still runs and has good picture but this arc after a few minutes causes a big shock and the tv shuts down,...
The flyback should be replaced your model uses the 270125 flyback. Its a easy repair. You can get the replacement 270125 flyback from www.tvrepairworld.com and they send a Cd with detailed instructions on how to do the replacement.
Jan 23, 2010 | RCA HD52W59 HDTV Projection Television
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
I have 52 inch rca projection hdtv when I turn it on from the back of the tv a loud piercing noise rings out what could this be from?
REPLACE THE HIGH VOLTAGE BLOCK, PART # 258512. AND RES. PART # 238958.. OR LOOK FOR A BULGING CAPASITOR ON THE MAIN BOARD AND REPLACE IT.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
163 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
