Question about Toshiba SD-4700 DVD Player
Toshiba SD-K760SU Spindle motor actuation failure
This seemed to show the same symptoms as the one that suggested the ribbon cable problem.  Insert and "Load" Then "No" on the readout.  I reinserted the ribbon cable and then tried to load the Disc.  It seemed to exhibit the same malfunction and code.  But as before it seemed to try to spin up and not succeed.  I gave the top spindle a little nudge and it spun up and started playing.  What needs replacing here?  The spindle motor unit? Or a single small component somewhere? And what is the number of the unit in order to get it.
  • 1031 Answers
SOURCE: Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Posted on May 24, 2008
SOURCE: Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Posted on Aug 12, 2008
  • 34 Answers
SOURCE: Will not play all DVD's
Try a dvd lens cleaning kit. This may help.
It could also be the laser itself. Newer DVDs require a very strong laser to read them.Older ones do not.
You can pick up a cleaning kit at Wal mart for about 10 dollars.Hope this helps
Posted on Sep 18, 2009
  • 10421 Answers
SOURCE: My Toshiba SD-1600 dvd player will not load my
Hello, please get the code here :
Best Regards, Jay_bnh9i8
Posted on Feb 27, 2011
  • 33 Answers
SOURCE: my toshiba sd-p91s portable dvd
Have you tried using a dvd player cleaner?
Posted on May 04, 2011
Touch Screen Not Working. Have cleaned the ribbon cable contacts and still the screen lights up showing the buttons but nothing on the touch pad works. If not the ribbon cable being dirty, I guess i
Most of the time the panel buttons stop working because grease gets between the outer panel and the contacts underneath. Disassemble the door and if you need to carefully peel back the outer panel, use some paper towels to remove the heavy grease, then using a Q-tip and some rubbing alcohol clean the back of the panel and the surface contacts on the board, then re-assemble.
Dec 26, 2014 | In Microwave Ovens
How do I insert the daisy wheel on my Swintec 2416 DM typewriter?
Remove the ribbon, then remove the daisywheel, reinsert daisywheel, replace ribbon and it should work.
Jul 01, 2014 | Swintec Office Equipment & Supplies
Hp 6100 line sensor removal
Line sensor calibration has must to do if Line Sensor is disassembled or replaced.
In the Service Calibrations submenu, scroll to "Line Sensor Calibration" and press Enter.
Follow the snaps for replacing the line sensor...
25d7979f-a076-4169-b132-c2e364b4aca5.jpg 8bedcfbb-4a1d-47c1-8e07-c63d3522b584.jpg
Apr 09, 2014 | HP Designjet Z6100 InkJet Printer
We had a power loss and when the power was restored the readout for my range said F1. The burners work, but not the oven.
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Aug 29, 2011 | Amana Ovens
I flipped what appeared to be a small switch between the battery slot and the SD slot. It uncovered what looks like a small 3 pin connector and now the camera will not turn on. Any suggestions?
It might be a ribbon cable connector you "unhooked". Try to replace it back to normal by reinserting the ribbon cable into the slot that has the locking mechanism that you thought was a switch.
Jan 20, 2011 | Nikon COOLPIX P3 Digital Camera
My kodak c-195 series digtial screen is white and blurry. how can i fix it?
A white screen usually shows up due to problems with the lens ribbon cables most of the time.
If you have some technical background, then try to do the following. Otherwise you could mess up the camera.
You need to open the camera and look at where the cables plug into ribbon holders on the main circuitboard. You may need to remove LCD screen and also the plate under the screen which holds the screen in place. Once the plate is removed, the lens ribbon cables are accessible. These cables may get misaligned over time. Carefully lift the pressure plate in the ribbon cable connector that secures them in place. Slowly pull out the cable. Clean it and reinsert and close the pressure plate. Reverse the procedure.
Jan 10, 2011 | Kodak Cameras
When i turn it on the screen is white and dose not show any thing
Can you take pictures with it? Try to take pictures and then try to download to PC. If it is ok, then the LCD screen may be bad or the Ribbon cable may be misaligned from its connector. Open the camera (a few screws). Lift the pressure plate in the LCD ribbon cable connector gently, and pull out the ribbon cable. Reinsert it and close the pressure plate. If that doesnt help, I suspect the LCD. You may need to replace the LCD.
Jan 03, 2011 | Olympus FE-170 Digital Camera
How do I remove the keyboard on a Samsung R610 laptop. I have been able to remove the keyboard, but can't seem to unclip the cable that connects the keyboard to the motherboard. Is there some special...
The keyboard connector come in two types.
A plastic connector and usually has a plastic tab that you pull to lift the connector off, DO NOT PULL on the ribbon cable.
The other type is, a ribbon cable that is inserted into a plastic socket on the motherboard. To release the ribbon cable, lift up the plastic catch on both ends of the to release the ribbon cable. When you want to insert the ribbon cable, make sure the catch is in the up position before you insert the ribbon cable, then insert the ribbon cable and the push the ends of the plastic catch down to lock in the ribbon cable.
Aug 04, 2009 | Samsung R610-64G Laptop
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Toshiba SD-4700 DVD Player Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
