Question about ViewSonic PJ588D Projector
Viewsonic pj588d hi please help!! im not able to move the position of the image horizontal or vertical cause the options are desabled
3 Suggested Answers
BoiseLCD
  • 63 Answers
SOURCE: Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
Posted on Apr 03, 2009
budmrtn
  • 11361 Answers
SOURCE: "Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Posted on Feb 15, 2010
My viewsonic Va1912wb flashes horizontal lines when you turn it on and i know it is not in pal and it is not the refresh trate help me please
Hi There and Welcome to Fixya.
Horizontal or vertical lines flashing/running across the screen poses serious display issues with any LCD/CRT monitors. It only boils down to 2 possible causes :
  • Corrupted video driver
  • Hardware issue
To help you determine which of the above, here's what you need to do.
  • Ensure that the computer is turned OFF
  • Disconnect ALL USB devices except the keyboard
  • Turn the computer on and immediately hit "DEL" (in some systems, it's the "F2") key repeatedly until you reach a different screen. (not the usual Windows screen)
  • Welcome to the BIOS screen
  • From here, spend 30min to 1 hour observing if the lines are present in this mode
If you still see the horizontal lines, then there's a need for the monitor to be serviced by a certified/trained technician. The link below will direct you to their support page for repair/replacement options, depending on your warranty status :
ViewSonic Support
Otherwise, the problem can be resolved by re-installing the operating system.
I hope this helps, Thanks for using Fixya.
Apr 09, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
I am getting vertical bars moving up on my screen
vertical bars in video can be caused of poor filtering of voltage on the power supply,you need to open the back of the tv to repair the power supply.replace all bulging capacitor this causes the problem.Tnx
hope this help.
please rate my help.
Jun 05, 2010 | ViewSonic VA1912wb 19" LCD Monitor
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Ghost image in different color from main image - text appears "doubled"
Use the remote to access the menu and you'll be able to POSITION the colors horizontally and vertically .
You should be able to align with the other colors to make it sync'd.
Dec 16, 2009 | ViewSonic PJ551 Multimedia Projector
ViewSonic PJ588D
Try Function-F4 to toggle the display
Mar 26, 2009 | ViewSonic PJ588D Projector
Weird water-like image distortion
this is electronic advice,dont do with yourself if you dont have experince about electronics,it will be very dangerous...if you have experience then you do this...
you open the lcd and you remove the power supply chips, it contains more capacitors like 1200mF 16v..i think so..but check the voltage if it is correct in the volt meter,caused the sounds like power distortion..if the voltage is less the screen will be "trembling and shaking, its like very frequent water ripples. This problem though dissapears as you move more and more to the right, but its clearly visible to at least no the 1/3 of the screens horizontal length." check
Mar 03, 2009 | ViewSonic VG2230WM LCD Monitor
Invert picture
Hi!
That choise is under the image options.
Those options look like this
clock
phase
horizontal position
vertical position
blanking
overscan
aspect ration
I hope you can find that in the menu, if not let me know and i will find the manual for you
Good luck
Please take a moment and rate my help for you
Nic
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
ViewSonic PJ588D Projector Logo
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
