Question about Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV digital camcorder
Dear Sir,
My SC-D363 Mini DV digital camcorder, keep on appearing on the screen "eject tape". I have to eject the tape and put it back again but once you play or put it in record, the same thing appears "Eject tape". Kindly help me solve this problem. My cam corder is new .
  • Vill Oct 03, 2008
    I am from Philippines and I will appreciate very much if you could give me the service center located here in Metro Manila, Philippines, where in I could drop by for service of my Samsung SC-D363 Mini DV Digital camcorder.
    Thank you.
    Vill
    Master:
  • 763 Answers
Sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
Posted on Oct 03, 2008
Rejecting tapes
I had the same problem with my SC-D363. My screen would flash "D" and tell me to eject the tape.
Here is the SOLUTION:
1) Very Gently unscrew (4 screws)and remove the front casing portion of the camcorder, be sure not to strip the screws.
2) Directly underneath the lens there is crosslike metal support that extends from the tape
compartment chassis. The green circuit board should rest on top of it as shown below instead of
underneath it, as it was when it was assembled.
And Voila! Camera works like when it first came out of the box.
Custom Car Parts
Jun 06, 2012 | Samsung SC-D453 Mini DV Digital Camcorder
My samsung camcorder keeps showing eject when i try to record
Possible that the mode switch is jammed or the eject button is jammed. It can also be that the drive had not completed and so urges the motor to eject so as to complete the loading. failure of sensors cannot be ruled out.
Jul 19, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
How do I get the drivers for my Samsung SC-D363 Mini DV Digital Camcorder
You can download drivers, other software and manuals for this camera from this page
Oct 16, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC D363 camcorder displays green wide lines on playback function what is wrong?
Sounds like dirty video heads which is going to require a mini dv cleaning tape to clean the heads and the tape path. Worst case scenario if cleaning doesnt help is that it may need the video heads replaced. I hope this helps.
Sep 15, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
I have d symbol problem with my 363i samsung handycam
eject d ?
this is a bad tape transport. something is miss aligned in head or a broken peice in the transport
Jan 25, 2009 | Samsung SC-D363 Mini DV Digital Camcorder
I want to copy video footage from the tape to the sd card.
Hi!
You cannot transfer the video from Mini-DV to SD card within your camera as your camcorder does not have this feature. If your purpose for finding this function is to transfer your footage to your computer, you may try using the firewire port in your camera to connect it to your pc.
If you need help with the firewire connection, feel free to post a follow up.
Hope this helps!
Nov 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
I have vertical multicolor lines
I think u are using pre recorde cassetts that were recorded on any other camcorder..
Samsung D363 supports ntsc not pal....
and the cassetts recorded on pal must have prob with ntsc based device...
all u have to do is record cassette with the same and then test playback...
Feb 25, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung sc-D363
I had the same problem. The batteries do not last. When the battery becomes weak it can not run the tape so it tells you to eject it.
Buy a new bigger battery. I bought a 160 for ~$30.
Jan 17, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV Digital Camcorder Logo
342 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
