Question about Car Audio & Video
This damn stereo
My best friend in the whole world gave me his old eclipse in dash cd player cause he got a new pioneer premier.sounds innocent enough right? He failed to tell me the reason why he did this. His battery was removed from his vehicle while the engine was being replaced. I thought ok, so? reinstall the battery and push the reset button somewhere on the face. Right? its not that easy is it. his esn disc was used as a clay pigeon along with his other collection of poorly burned cds. short of spiking the whole unit with a gigawat of electricity ive tried everything to circumvent this incredible anti theft deterrant. can you help me make a new one?
  • Car Audio & ... Master
  • 16,806 Answers
Mitsubishi will send you the code if you follow the directions here:
Posted on Apr 07, 2017
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
SOURCE: Vt Holden Commodore stereo wiring diagram
hey mate, i changed the unit in my vt, went to the holden dealer and they gave me a wiring sheet for the vt commodore range, the basicmodel, berlina and calias all have different units, the sheet tells you what wires are which for each head unit. hope this helps. stuie
Posted on May 21, 2008
SOURCE: Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Posted on Sep 10, 2008
  • 22306 Answers
SOURCE: How to reset anti theft in 97 Eclipse
dealer only
Posted on Feb 13, 2009
  • 4 Answers
SOURCE: anti theft engaged for no reason
That one your going to have to goto the dealer for. I think the alarm you have is after market, so you will probably have to if them check it.
Posted on Apr 01, 2009
Find the wirings for a pioneer premier DEH-P780MP
sorry to tell u this but u going to has to buy this cable fron pioneer , cost about $20-$35 , or u can go to a tv shop or car stereo places and see if they have one for less
Apr 15, 2010 | Pioneer Premier DEH-P670MP CD Player
I installed my new aftermarket CD player on my 1999 Pontiac Grand AM today but as I was putting into the car, the yellow power wire sparked and it wouldn't work. So I figured I blew out the CD player but...
sounds like you have melted the ill. wire into the 12 volt constant somewhere in the wiring harness. You have a few options you can fix it by tracing down power wire behind the dash seperate the 2 wires and tape them back, but that involves taking out the dash to trace them. You could replace the whole harness which again requires taking apart the whole dash and is expensive, or you could run the power wire down to the constent on your cigerette lighter. Find a wiring diagram or test the wires to see which is which. NOTE: always unhook the battery when you are installing a new stereo because the constants are just that a contant 12 volt feed. but to test the cigerette lighter wires you will need to leave the key off and battery on gound your meter to something and which ever wire gives you voltage is the one you want.
Mar 08, 2010 | Pioneer DEH-2100 CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
How to change color display
to change these types of setting you must turn off the stereo (hold off) then PRESS & HOLD the menu button (mines a different model but the menu button is pressing the volume knob )
Feb 25, 2009 | Pioneer Premier DEH-P580MP CD Player
Need a manual for a pioneer premier car stereo
Try this link, it is Pioneers website and you can get the owners manual for your unit if they have it. You did not list your model number, so i could not verify if they have it.
Nov 21, 2008 | Car Audio & Video
How can I connect my sony mp3 player to pioneer deh-5800mp in dash stereo
Hello nmfsc,
I am not specifically familiar with the DEH-5800MP but many car stereos these days have an input jack on the faceplate (or under it) which is used to connect the stereo to a MP3 player using a special cable which is available from the manufacturer.
If your stereo doesn't have an input jack, there are other options. One popular method is to connect a wireless transmitter like this one to your MP3 player set to an empty FM radio frequency which you can receive using your car stereo
Best Regards,
"Go Ahead. Use Us."
Jun 05, 2008 | Sony Network Walkman NW-HD3 MP3 Player
Cd error-ao pioneer deh-77mp
I read a solution on here where you disconnect the wiring harness for 30-60 mins. to release the power stored in the capacitors. It seemed to work for everyone. I don't know if you tried this for this amount of time or not. Also, have you used a cd cleaner disc? You laser eye may be dirty. Also, since you said it was an old, battered car, maybe the vibration is causing the unit to malfunction. Also, if the unit is installed at the incorrect angle in the dash, it can cause a problem. Hope this helps...
Jan 16, 2008 | Pioneer DEH-1900MP CD Player
Cd/stereo not working
Hi, The "sec" could probably stand for security lock. It is a feature to discourage car stereo theft but is prooving to be more of an owner's problem when battery dies or are replaced or simply when disconnected for maintenance or whatever. The sad part is you have to get in touch with the original dealer of the car who would probably ask you for registration papers, proof of ownership (deed of sale), VIN, make/model/serial number of the stereo and/or other documents. I know its a bit of inconvenience but there is not other way since they have to check a database and fill in so many data themselves. I just hope the dealer is friendly enough. Good luck and kind regards.
Aug 06, 2007 | Pioneer DEH-P44 CD Player
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
