Look inside the battery compartment and check the label. There may be a version code listed on that label. The GE remotes were manufactured by Jasco and the code lists are here: http://jascoproducts.com/support/ge-universal-remote-codes . Use the correct code list for the version for your remote. Note: these codes work for remotes sold in 2006 and later. For older GE remotes that use a 3-digit code, try this site: http://www.eliztech.com/remotes/ge-new-3digit-tv-codes.php .
I hope this helps.
(the remote control codes will often be limited to TVs that were sold at least 6 months before the remote was programmed. If your TV is newer than the remote, you may need to update your universal remote.)
The code that worked for me was 135.
Other Orion codes are 035, 121
Four digit codes for newer remote models might be one of the folling.
0236, 0179, 0463
Good Luck!
I LOST MY INSTRUCTION MANUAL AND I NEED TO GET THE TV CODE TO A sony "tv" I have an sony T.V. and polaroid. My problem is that I have no code no. for the T.V. and no instroction for the remote. Please help
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
what are the codes for philips tv?
