Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk Cruzer® Micro 2GB WON'T Download pictures
I copied pics from my daughter's computer on to my SanDisk Cruzer® Micro 2GB SDCZ6-2048-A11 last month. I then deleted them from my camera. I need these photos. When I plug it into the USB port, my Adobe Photoshop opens up and looks like it is going to download them. I can see thumbnails of the photos (400 of them). But when I click on the "Get Photos" box it only downloaded 10 photos, and then gives me this error message:
"Cannot obtain all files from this device. Please ensure that the device is connected properly, or the battery is charged. The files that have been obtained till now will be sent to Adobe Photoshop"
If I let my camera wizard open it, then choose copy to my computer, I get another error message that says:
"The Current picture could not be copied. To copy this picture click "try again", to skip this picture and copy the rest of the pictures, click "Skip"
to cancel, click "Cancel".
If I choose try again, if fails. If I choose Skip, it just goes through all the photos with the same error, then it closes out.
HELP!! I really need the pics on this flash drive for work!! Please give me step by step instructions to solve this problem. The computer that I copied the pics from is in Colorado and I am in Utah!
Thanks so much!!
  • Peter Clark
    Peter Clark Oct 21, 2008
    I save pictures to the flash drive and they are recognosed by the computer and I can both see them and print them. I took the drive to Asda to get the pictures printed and their machine tells me that there are no pictures on it. I copied the same folder of pictures to a CD and that was recognised Ok. I have freformatted the drive and copied the folder to it using Roxio, drag and drop and "send to" all have the same result. Can you suggest where I am going wrong. Word and Publisher files work Ok.
    President:
  • 1,901 Answers
Try using Windows Explorer to copy them. I'll try to help you out.
When you plug the drive in and a window pops up, select "Open folder to view files using Windows Explorer". If they show up in the right pane as thumbnails, select View>Details from the menu at the top.
Left click the top picture, then scroll all the way down to the bottom. Press and hold the <Shift> key, then left click the last picture in the list. This should highlight all the files.
Right click on any of the pics, then go down to "Send to...". This opens several choices, but you probably should choose "My Documents". This will copy all of your pics into your My Documents folder.
Once you get them there you can move them to your My Pictures folder in much the same way.
Posted on Oct 16, 2008
How can i save a program to the cruzer micro 2gb from my computer?
Hi:
You can't save a program that is installed on your computer, but there is an option. You can install a program to your cruzer, or if a program is a downloaded program, you can download and save it to your cruzer, before you install it. This is like this, to prevent software piracy... Otherwise, I could steal a program from any computer, and copy it to a flash drive...
Nov 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My daughter gave my 3 sandisk micro 4gb zip drives I want to store my photos off my PC on them , out of My Pictures and Picasa, to free memory. I would like to load them back on a laptop when needed to...
If you are using a Windows computer, then double click on "My Computer" after you have pluggen in the drive. Under "Devices with Removable Storage", there should be a drive called "Removable Drive" or "zip drive" or something along those lines. Double click on it. Now, open up where the pictures are on your computer (likely in "My Pictures", as you said). Highlight the pictures you would like to copy, and right click and select "copy". Then go back to the zip drive window. Right click and select "paste". Hope that helps you out.
Oct 26, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a compac vista laptop and am trying to download pics on my sandisk cruzer micro 2gb Any instructions available?
All you have to do is drag the pictures off your computer onto the cruzer drive. You can treat it just like a 2nd harddrive.
Oct 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to trans pictuces from picasa to sandisk cruzer usb2.0 flash drive
Hey.
Transferring picture is a simple way attach you picasa to your computer attach also your usb flash drive. you can copy picture from your picasa and paste it to your usb flash drive.
Regards
ICmanServer
Jul 31, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Instructions on how to upload a powerpint
Hi...
What did you mean, if you want to save power point in you Sandisk, it is not upload it is only save. you can save this true copying files form your computer, then paste it to your sandisk folder.
Regards
PCmania
Jul 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How can I copy from internet to my Cruzer sandisk(micro 2GB)
First you need to download the clips to your computer, then move it to the flash drive.
May 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Downloading computer photos to my 2gb sandisk
Really easy! Drag and drop the pictures into the USB.
Hope this helps!
Nicholas CHUM
Apr 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Do you have SP2 on your computers....? and is there any error that is shown whenthe USB drive is inserted into your computer?
Apr 14, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
153 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
