Oct 03, 2008
- Polish
the terminals with a dry cloth and make sure the terminals are clean.
If the terminals are covered with oil from your skin or similar matter,
this may cause poor contact and battery power may not be fully supplied
to the camera.
Also,
polish the battery charger terminals with a dry cloth before charging
the battery. If the terminals are covered with oil from your skin or
similar matter, this may cause poor contact and the battery may not be
fully charged.
If the lens does not extend then it is possible that it has become
jammed. Sometimes this can cause the camera to sense an error and shut
itself down immediately after powering on.
There
are other explanations for the behavior, but if the lens does not move
this is the most likely cause. If the lens does extend but then the
camera shuts right back off it is possible that an inner component such
as the focusing element is not functioning properly
One more thing you can do is once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries.
you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries..
If you still face the problem then you will have to get it repairedIf this is under warranty replace it or else get it repaired from:
http://www.advancecamera.com/repair/They give:
- Free estimates.
- Reasonable rates.
- Fast, friendly, and personal service.
- Top quality repairs.
- Advance Camera 1 Year Warranty.
If you need anymore help let me know.
