Question about Shuttle MK32N Motherboard
Mk32n board that keeps on restarting
I have a mk32n board that keeps on restarting it sometimes turns on the monitor and sometimes dosnt i is running an athlon 2400 cpu can u help me plz
  • 781 Answers
Remove side of case and clean all fans and ensure heatsink vanes are clean
Also clean power supply fan
Vacuum out inside of case making sure all vent holes are clean also the power supply rear vents
this method has got numerous computers back to operating properly
Posted on Oct 06, 2008
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
Hello my problem is my fan,i read many solution's about dirt and overheating so my try was to open it clean it but...sometimes stop's working..dunno how to set it on if there is any way to do that,and...
The Fan on your laptop is automatic. It starts when your laptop gets warm and turns off when the temperature is lowered. I dont think it needs fixing of any sort.
Aug 30, 2010 | Acer Aspire 5100 Notebook
Im using ASUS VW193T LCD monitor for my pc...the problem i encounter now is that it turns off automatically but my cpu still on then it turns on again...sometimes it turn off then when it turn on again my...
im quick guess would be nyou have a Bios MotherBoard Video Card Problem. If you are using an on board video card then that doubles your chances or it being *********** boards fault. Also do a google search for ways to reset *********** boards bios that can sometime do glory to unresolved problems. What happens if you hold you off button down for a long time (40seconds)
Feb 01, 2010 | ASUS Computers & Internet
Monitor goes blank after random time sometimes
no i guess itz not the graphics card..itz probably causing from faulty or defective ram or main/mother board..
however, proceed to verify with the below stated steps, only if u r a professional..
DO IT ONLY IF U R A PROFESSIONAL..
..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
7)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
8)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
plz give priority to steps(2, 5 & 6)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 16, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
CPU Upgrade
Hi there.
Here is a list of processors that board will support >>>>>
http://www.cpu-upgrade.com/mb-ASUS/M2A-VM.html
Good luck and thanks for choosing FixYa!!
May 27, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
Dont have sound driver cd for amd athlon xp 2400 so plz get me sound driver
Is the sound-card "integrated" into the motherboard, or is it a separate adapter-card that is connected to the motherboard?
If the former, then the manufacturer of the motherboard will have the device-driver available on their web-site.
If the latter, then the manufacturer of the sound-card will have the device-driver available for download from their web-site.
Or, try "Windows Update" and "custom" and then look in the "Optional Hardware" section.
May 21, 2009 | AMD Athlon XP 2400+, 2 GHz (AXP2400BOX)...
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
MOTHERBOARD UPGRADE
1 yes,
2 buy a new board and chip, trust me spend as much as you can and as much memory as you can afford and laugh at the snails pace of your old system
Nov 05, 2007 | MSI KM4M-L Motherboard
Shuttle MK32N Motherboard Logo
73 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
