Question about Samsung SC-L610 Hi-8 Analog Camcorder
Works on ac power only-battery does charge
My Samsung SCL-610 will work on ac power only. When I plug it in the battery charge light does work--and battery appears to charge-but camera will not run when unplugged. It's been a LONG time since lithium battery was replaced--might that be the problems?
  • 62 Answers
Try to change your batery..
Posted on Oct 03, 2008
Since the date and time were being maintained--decided the lithium battery had nothing to do with the problem. Actually had purchased a new rechargeable battery--took it back (after it had charged) and it was fully charged. Decided to take the eraser of a pencil to clean the metal contacts on the camcorder and the batteries---now works like a charm!
Power light is red , does not charge battery, battery light flashes red
The onboard connectors that your battery connect to on the motherboard no longer work that is your battery is not charging.
Dec 04, 2012 | Gateway LT Series Intel Atom N570 1.66GHz...
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Compaq 610 laptop will not power up, any fix?
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 05, 2012 | HEWLETT-PACKARD Compaq 610 Notebook
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
No power in Samsung Q45 laptop
BATTERY IS BAD COULD BE CAUSED BY LEAVING AC ADAPTER PLUGGED IN ALL THE TIME ORDER NEW BATTERY COST LOW ON EBAY AROUND 20 BUCKS
Jul 23, 2017 | Samsung Q45 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
aneesnv@msn.com
Dec 18, 2008 | Dell Latitude D600 Notebook
When ac is plugged in the power light blink & notebook unresponsive
Sounds like your ac adapter (brick) is bad and not supplying correct voltage/amperage.
Apr 03, 2008 | Toshiba Satellite 2805-S603 Notebook
Samsung SC-L610 Hi-8 Analog Camcorder Logo
158 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
