Question about Acer Computers & Internet
I have a problem with an Acer travelmate 530 no sound output anyone got any ideas
  • 781 Answers
1. check the obvious first:(check... don't assume)
a.everything is plugged in .. if possible test the speaker to make sure they're working
b. is your volume all they way up (or at least not all the way down).
c. click once on the speaker icon on your system tray (where the clock is) make sure you're don't have the sound muted or the volume is all the way down.
d. now double click on the speaker again and check the mixer volume control.. check items like master volume, wave, audio cd and others are not muted or with the volume all they way down.
2. if after doing step 1 everything check out ok you you may have a possible driver problem: note: if you see the speaker icon with a red cross (red cross means there's no driver for your sound controller) you need to check device manager for a possible driver problem, do check even if there's no red cross on the speaker icon as it may be a possible outdate driver (for device manager go to start>run> type devmgmt.msc then enter) and check if you have any ! or ? under sound devices. if you do unstill and reinstall drivers or better yet, download updated drivers from sound card manufacturer.
3. if you got upto step 3.. you may have a faulty sound card, get another sound card and test if it works. (this is unlikely but possible)
Posted on Oct 03, 2008
Microsoft universal audio architecture
Don't forget to download the drivers from acer.
Dec 07, 2013 | Acer Computers & Internet
Acer Travelmate 6592G Charging problem
The power adapter id under powered by 1.32A that is why it takes a long time to charge and it is putting a lot of stress on the adapter and could cause it to overheat. The ticking sound could be the thermal cut out cutting the power to the laptop to prevent the power adapter from failing.
Mar 17, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
My notebook can not be heard from the main speakers and can be heard very low from the speaker output
install the acer sound driver again & try. If not success then the mother board sound driver is damaged and need to repair. Thanks.
Nov 28, 2010 | Acer TravelMate 212TXV Notebook
How can i install a wlan card into my travelmate 240? I know where to plug in but i have no idea where to place the antenna for it. Does anyone know?
"How can i install a wlan card into my travelmate 240? I know where to plug in but i have no idea where to place the antenna for it. Does anyone know?"
Your laptop is equipped with wireless already, see here:
LINK to specs
If not, use any of the USB ports and if it prompts you for software you would need to get the driver onto a USB memory card to install it.
May 03, 2010 | Acer TravelMate 240 Notebook
Acer3260 headphone no output
has a problem with the sound card because there is no audio or can be a cold solder point
Aug 22, 2009 | Acer TravelMate 3260-4874 Notebook
No sound on my travelmate 530 ascer laptop.
try to download from this site.
http://members.driverguide.com/driver/detail.php?driverid=207559&si=4355e422ede7306dd6f20b063e262a6e
then click the download this file from your lower right portion of yout screen. this is similar from your driver i think you can use this one.
May 31, 2009 | Acer Aspire 3680 Laptop
Acer travelmate 4025cl sound problem with vista
you can run the mother board cd once.click for repair.i suppose that will do.
Oct 28, 2008 | Acer TravelMate 2300 Notebook
TravelMate 530 CMOS Battery
You BIOS setup at the time of bootup should have a reset to factory settings. However if it requires a password you may have trouble getting into it.
Some notbooks have a battery you can pull off the motherboard to reset it back to factory settings. It usually is a small lithium battery.
Aug 27, 2008 | Ricoh Aficio 1035 Copier
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Computers & Internet Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
