Question about Ricoh Aficio 1018D Copier
Functional Problem with RICOH Copier Error No-SC:541
Dear Sir, Functional Problem with RICOH Copier Error No-SC:541
Above is the main problem with RICOH Copier no anyother key can be used so if Sir could share to me i will be greatful
Sangay
  • 1 more comment
  • swangchuk555 Oct 03, 2008
    Sir ,
     How to solve the Error No SC:541 plez help us to solve the problem
    Sangy
  • sarav9816
    sarav9816 Feb 29, 2012
    sir sc 549 this which type error and soultion
  • Anonymous Mar 24, 2014
    copier not functioning
  • 38 Answers
YOU NEED TO RESET THAT CODE
Posted on Oct 22, 2008
    New Friend:
Dear, I am facing the problem of Copier Nashuatec 1805 Aficio, the proble is indicated by functional problem Sc 320. How to clear this?
Posted on Oct 23, 2013
    Problem Solver:
  • 14 Answers
After you replace thermistor still the problem occur since you need to reset even after you replace a new one..try reset again.
Posted on Apr 18, 2013
    Habit-Forming:
    Scholar:
  • Ricoh Expert
  • 129 Answers
1. Check that the thermopile is firmly connected.
2. Replace the thermopile.
Posted on Feb 03, 2016
    New Friend:
Machine reset or replaced the thermistor
    New Friend:
Where could I find the thermoster
Posted on Sep 28, 2014
  • Ricoh Master
  • 2,794 Answers
It's s thermistor error. A new thermistor will solve the problem.
Posted on Oct 03, 2008
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Factional parablems ricoh aficio 400
it really need to be wrote which specific functional problem is showing, as example SC 541.
Feb 19, 2014 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Error sc 541
This is a fuser error. I found the following solution here on Fixya and it seems to have helped.
"Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power."
Sep 02, 2012 | Ricoh Aficio SP C311N Color Laser Printer
Ricoh Affcios 3025 Functional problem with copier
Hello!
This code is related to a Fusing temperature error.
You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do not have technical knowledge)
If you still want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 04, 2011 | Ricoh Aficio 3025P Black and White Copier
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
2,109 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
