Question about Cameras
Can't locate my manual and need to know how to set the timer on my minolta dimagez1
  • 48 Answers
Hello
You can download the Minolta Dimage Z1 manual from the following link
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/index.html
I hope this helps
Posted on Oct 03, 2008
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I want to know how can I set the self timer on for my minolta G500
Repeatedly press left/right on the selector to bring up the self-timer mode (one-handed clock). Start the self-timer by pressing the shutter release button.
Refer to pages 38-43 of the manual for further details. If you need the manual, you can download it at
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-g/dimage_g500/D_G500_E.pdf
Dec 25, 2010 | Konica Minolta DiMAGE G500 Digital Camera
How do I work a GE 24-hour timer? There were no instructions. I don't know if I'm supposed to have the lamp turned on or off in order for the timer to work.
Yes the lamp must be turned on.
Bulb must be in working order.
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
If link above does not show your timer, then add a comment
The GE 15004 timer does not have a manual at Jasco, so many folks write in about this timer
To set the timer, rotate dial until current time lines up with pointer located on inner dial.
The trippers are located on outer edge of dial.
I'm am guessing that you move the trippers around to time, and then push tripper inward or outward.
I have looked at enlarged photos of timer but cannot say exactly how the tripper is set.
Green tripper is ON
Red tripper is OFF
There is a switch located on side of timer.
Move switch to ON for timer to operate.
Plug lamp into timer.
Plug timer into wall.
To check on-off settings, manually rotate dial clockwise with your hand and watch lights turn ON-OFF.
Check switch is supposed to be set ON, by moving switch both ways.
You can also take advantage of fixya phone service.
Expert will talk with you via phone for a price.
Dec 25, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Hi i need to know how to set the timer on a konica minolta dimage z2
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock).
Jul 28, 2010 | Konica Minolta DiMAGE Z2 Digital Camera
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
Need to set self timer
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
Sep 06, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
HOw do I turn on the self timer
Hi - You can download the manual by clicking the link underlined in blue below:
DiMage Z1
See page 47:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 20, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Cameras Logo
111 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
