Question about Dell E173FP 17" LCD Monitor
Flat screen wont turn on
MY *** of a boy friend had a temper tantrum and knocked over my 19 inch flat screen monitor now it will not turn on, any ideas on what is wrong or step by step instructions on how to fix it! I am computer illiterate but willing to try to fix it myself if I have some help thanks.
P.S I am not at home and cannot remember the brand name of it
  • sxycwgirl101 Oct 04, 2008
    My monitor looks fine nothing looks damaged but when I try to turn it on, nothing
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
Hi ,my lcd screen powers up then the power light starts flashing green but still wont come on,any ideas please as i am a pensioner and cant afford a new one ,thanks graham.
Posted on Oct 14, 2008
    Genius:
  • 1,124 Answers
If your screen has been damaged, you have to replace the lcd screen.
Posted on Oct 03, 2008
How to open the HP 19 inch flat screen monitor
You need to remove the stand first, and then using small flat screw driver to release the four tabs at the bottom edge of the monitor.
I myself never have to replace the power switch on these series yet.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Green line running from about 3 inches in from rhs rising to about 1 inch from top of screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | Acer 19" Widescreen Flat-Panel LCD HD...
19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Mar 24, 2010 | LG 19LG30 19 in. LCD HDTV
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
I have a AOC flat screen monitor and it got wet and it will turn on for a few seconds but the screen is blurry and looks wet itself , is there anyway to fix this ?
hello my friend, try to blower your monitor. Open it and see if inside of the monitor is not wet cause if it is wet then it could cause some short circuit problem so the best thing to do is to let the monitor check if it is wet and dry it up before turning on
Jun 16, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
OOPS! How to invert screen image )get it back where it belongs)
just take it to the showroom where u got it from. this problem can be fixed without any big problems
Feb 20, 2008 | Samsung SyncMaster 912N 19" Flat Panel LCD...
HP Flat Panel Monitor is dead!
The power supply within the monitor has probably expired. HP doesn't do spare parts for their TFT monitors as they are Full Unit Replacement items (if in warranty).
Jan 25, 2008 | Computers & Internet
Power not being received by monitor
RMA it if its under warranty. Throw it away if its not.
Nov 10, 2007 | Gateway 19" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
140 people viewed this question
Alun Cox
