Question about Maytag Dependable Care LAT9706
Maytag Washing machine won't Agitate
My maytag top loader (about 15yrs old) won't agitate.
It will fill and drain just fine.
But for the agitation cycle, it will just spin.. clockwise..
Then for the "spin" cycle, it will spin... counterclockwise..
I drained it, and grabbed ahold of the agitator, and when I tried to spin it by hand, it would spin the entire assembly, both directions.. the agitator and the tub would spin together.
My wife hasn't heard the machine make any funny noises..
Any ideas?
  • g55sanchez Oct 26, 2008
    I smelled rubber like the belt was burning. Find pieces of it under the machine. It appears the machine is not agitating. It fills with water and drains w/no problem. What do you think it could be?
  • ErnestoDLS Nov 10, 2008
    I have the same exact problem with my LAT5006AAE model washing machine also.
  • 641 Answers
SOURCE: The drain pump only turns 1 turn counterclockwise and clicks to a stop. What happened?
To check the pump you should remove it from the washer and try to rotate its pulley manually to both sides. If it doesn't turn freely (frozen or stiff) look for foreign object inside the pump. In case the pump is clean and doesn't turn freely,you should replace it/ Good luck !
Posted on Aug 27, 2007
  • 1073 Answers
SOURCE: Kenmore F/L Washer Model 41743142200 tub loose
you may have a dampening shock that is bad
Posted on May 08, 2008
  • 25 Answers
SOURCE: Agitates forward but not reverse.
lower gear box coupling has sheared
Posted on Jul 03, 2008
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
  • 1902 Answers
SOURCE: ge wwsr3090t2ww wont agitateor spin
This is a pop off type. and The timer seems to have gone bad as long as the motor is turning and the belt is not stretched.
Posted on Feb 10, 2009
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Nov 29, 2013 | Maytag Centennial Series MVWC200XW
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Maytag top loader washing machine
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
533 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
