Question about Cyberhome CH-DVD 300 DVD Player
Battery Hello, I have lost the grey plastic holder for the battery to fit into. What can be done to fix this? Thanks for your help, Troy
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Using screwdriver open up remote, tape battery securely, make sure remote works and put it back together. You can also buy a universal remote to control it.
Posted on Oct 20, 2008
I have a Worx 14" mower. I just bought a new battery and it still won't start. Any suggestions?
ive been getting more of these electric mowers here for me to fix in the past few months now , ive gotta do a video on u tube on how to care 4 them , but enough of my rant , on to your question , ive seen this happen a few times folks don't order a spare battery right from the start with these things and buy one like a year or more later , what happens is over time of charge/use/charge old battery's heat up some , plastic holders become distorted a bit and when a new battery is installed it don't fit "just right" and hence the contacts are not making up right , what ive had to do is a bit unconventional but take battery out and use a hair dryer to soften up plastic in spots that hit new battery and bend them softly away . makes new battery fit correctly and contacts make up right , I think the fix for this is not to charge battery inside mower but take it out ,but on some that's not allways an option . ohh and allways ck safety switches there the same as a real gas mower
May 29, 2015 | Worx Garden
What size battery for masport 155/1056
The largest battery that fits the battery holder
i fitted a lager battery than the original factory as they last longer than the original more starting power
I cut the battery holder under the seat so to fit larger batt
Feb 11, 2015 | Garden
Needs new battery where do i buy one?
Hello, you can contact www.electricshaver.com as they stock most batteries for electric shavers for the major brands. If you want, you can give them a call at 1-888-476-1785 if that's easier for you.
This model might require the replacement of the main circuit board as well as the batteries, so it might be best to have the repair done by an authorized service center. If you prefer to have this done locally, you can check the phone book for a Phillips Factory Authorized Service Center near you.
Hope you find this Very Helpful and best regards!
Nov 10, 2009 | Philips Philishave Cool Skin HQ5620
Fitting a new battery to a bt contour payphone
I have a bt contour 100 that had the same problem no dial tone and nothing on the screen this is easily fixed by soldering in a new battery or soldering in a battery holder / battery back that takes 3 aaa batteries in place of the old battery you may have to solder two separate wires into the positive side and one wire into the neutral side after the old battery has been removed once you have soldered two wires into the positive thoes two wires need to be connected to the positive side of the battery holder and the other single wire into the neutral side of the battery holder once done correctly when you have inserted 3 AAA batteries and reset the payphone it will start working again bare in mind when you reset the payphone the pin number will go back to its default setting you may have to contact bt payphone help desk to get the default pin if you don't already have it there is a company offering to convert the bt contour payphone to run on regular alkaline batteries which are easily replaced but getting it professionally converted would come at a cost you can easily do it yourself giving some basic knowledge of electrical wiring and some common sense. The payphone runs on a 3v dc lithium battery that costs £9.99 on some sites on the Internet I believe that you can also get it to work on a 3v DC adapter but I have not tested or tried running my payphone on a power adapter as converting it to run on aaa batteries is easier and quicker to replace
Nov 03, 2009 | Lands Phones
I also have a 7000 that needs a battery holder and with cover
Rodger, I can't help you with a replacement battery holder. If you plan to keep the camera, after all its almost 25 years old, I suggest: Take it to a repair guy. Why? find out what caused the short, and fix that, or you will have the same problem again. Get another one on Ebay as a parts source. Hey, they are old cameras. Otherwise: If the camera came with lenses andstuff, go to Ebay and get another cheap Maxxum and use the lenses on it. It will have a faster autofocus, weigh less and be smaller.
Sep 28, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Changin the dust bag how do you do it?
1. open the bag compartment by lifting the black catch near the handle. 2. grip the grey plastic fitting on the bag, using the little handles on each side, and slide it out of the black holder. As you do this, part of the grey fitting remains caught in the black holder, and this causes the bag closure to cover the hole. When the cover is fully in place, if the grey bit doesn't release itself, you can help by slightly lifting the black tab where it's trapped. 3. slide the new bag in where the old one came out, and close the lid. 4. job done!
Jun 07, 2009 | Miele Cat & Dog 326i Bagged Canister...
Battery
It's the cca thats the problem here or cold crancking amps. Just make sure the battery fits into the battery holder and get one with as many cca as you can fit. You could even use a 4x4 battery with 700 or 750 cca if it fits in and you can secure it. But I would recomend you get a smaller passenger car size one as 4x4 batteries would be to big
Jul 18, 2008 | 1995 Ford Escort
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Cyberhome CH-DVD 300 DVD Player Logo
50 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
