I NEED EMU SOUND CARD DRIVERS
Hi, If you feel that, my answers have helped you getting solution to your problems then please give a vote. Thanks.
Please be informed that any hardware device needs a driver software to run within a PC, and the driver software depends on the Hardware Make/Model and the Operating System software you are using in your PC to operate it.You will get the Driver software of any hardware within the CD provided with the hardware part at the time of its purchase. The hardware may be an entire PC,Laptop,VGA card, sound card, LAN card etc.
If you do not have the CD or misplaced it somewhere then you need to download the driver software to get going. Thus you need to know all the above information to get the exact software your PC needs. As you have not mentioned the Hardware Make/model and Operating System you are using, i am unable to give you the direct download link.
However you can download the same by visiting the 'software downloads' section of the website of the hardware brand you have purchased. You just need to Google the name of the brand and visit their website and search for the download section.
if this is a problem with your computer restarting
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions EIDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need power and data to travel through every working device and to have a finishing point to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as faulty fan and the fans electrical lead can cause this problem
if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory
hope this helps you
