I have a Hyundai Q320 TV. I just got Comcast cable with a Motorola Box/DVR. I need a 5 digit code so I can use the Comcast remote with the TV. I can't seem to find one and it doesn't come up when I use the remote to search. Can you find it for me?
  • 1 more comment
  • scooter607 Oct 03, 2008
    I tried the 3 codes you recommended and found 1 more in the remote manual. Still no luck. Any other codes out there?
  • scooter607 Oct 04, 2008
    According to the Motorola remote instructions, it must be a 5 digit code. Any other possibilities?
    I have tried 10849,31254,10178, and 11017 and none of those are it. I have looked at the manual for the TV, the remote and Comcast remote. Could that Hyundai Q320/Q321 also be private labeled for another more common brand whose 5 digit code I can use and who does Hyundai private label for if any. It's frustrating to use multiple remotes.
    President:
  • 2,712 Answers
Best contact Comcast directly. You can contact them HERE.
Posted on Oct 04, 2008
    Genius:
  • 1,011 Answers
Dear,
Have you tried to just do a code scan on the remote.
If there is a code for your tv, the scan will find it.
regards,
dont rate it until u satisfied with it
  • SALMAN NASEER Oct 04, 2008
    dear,
    If the scan didn't find it, then there probably isn't a code
    in the remote for your TV.
    If it's an older remote you might try to get a newer one..
    The newer remotes have codes in them that the
    older ones didn't have!!!!
    regards,
  • 1,879 Answers
If the 5 digit code that Comcast provides didn't work, better call them.
    President:
  • 1,952 Answers
Try this code
10000
Posted on Oct 03, 2008
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Oct 03, 2008
    download tat pdf and get ur code
    To program the remote to work with your tv, you need to take the following steps:
    1. Find the code or codes for your TV from Comcast's list [PDF]
    2. Turn your TV on
    3. On the remote, press and release the TV key on the very top of the remote.
    4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
    5. Using
      the number pad, enter in the first 4-digit code found next to your
      television brand on the chart. If you do this correctly the "TV" key
      will flash twice. Now it's programmed!
    6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
    this code will surely work try this 5 digit code
    01376
    00476
    00810
    00276
    01187
    01254
    thanks for using fixya...rate this solution
    mohammed marika thambi Oct 04, 2008
    0849try its code or below codes
    DCT6208/6412,DCT6208,DCT6412
  • 6,487 Answers
Try doing this:
1. Choose an unused or unneeded button on the “silver” remote to be the 30-second skip command. I used my “A-lock” button, and in retrospect that’s probably not the best choice, but I wanted it near the other DVR controls. Other choices are the PIP buttons at the bottom, or the “help” button.
2. Press the “Cable” button at the top of the remote to put it into Cable Box control mode.
3. Press and hold the “Setup” button until the “Cable” button blinks twice.
4. Type in the code 994. The “Cable” button will blink twice.
5. Press (do not hold) the “Setup” button.
6. Type in the code 00173.
7. Press whatever button you want to map the 30-second skip command to.
Hope that helps....
    Genius:
  • 1,269 Answers
I've been searching for the code as well but unfortunately, the remote that came with it doesn't have one. What I can suggest you is to use a universal remote or a newer remote with good extra features that you can enjoy. You can visit HERE
    Sergeant:
    Champion:
  • 435 Answers
Hi, The 5 digit is unavailble to this TV so, try this.
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Note: Use the AUX key to program the remote for an audio receiver or DVD player.
Checking the CodesIf you have set up the remote control using the Searching For Your Code procedure, you may need to find out which four-digit code is operating your equipment. For example, to find out which code is operating your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
  3. Enter 9- 9- 0. The TV key will blink twice.
  4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks = 3) and write down the number in the left- most TV Code box (at end of this section).
Note: If a code digit is "0", the selected mode key will not blink.
Repeat step 4 three more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit. To check another device code, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are checking.
You can find more in here:
http://www.comcast.com/remotes/universal.html
If you are looking for remote manual in case. its here:
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_on_demand_remote_manual.pdf
  • 360 Answers
Hyundai 10849 here ya go man
    Genius:
  • 1,124 Answers
On the manual of the comcast must be included your tv code.
One For All URC 7781 remote codes for Hyundai: 0037, 0865, 0556, 0706, 0860, 0753, 0698,1376
    Genius:
  • 1,689 Answers
Scooter, you may first try to use the ff codes:
31254
10178
or
11017
Here is a list of codes from Comcast:
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/codes.pdf
here is the manual for your Comcast remote:
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Hope this helps.
  • marlon john madrid
    marlon john madrid Oct 03, 2008
    no problem...
    those codes where from comcast. if it still did not work then try the other options that other fixya techs gave out, and as a last resort, you may want to call Comcast to have them give you a specific code for the set if they have a unique one.
I need a remote code for my tv for a comcast remote i have a sansui tv thank you
hi,
Try the following codes
5 digit code :- 10463, 11409, 11904, 11911,11935 (Comcast Universal Remote )
4 digit code :- 0463 (COMCAST - CUSTOM DVR-3 DEVICE UNIVERSAL REMOTE CONTROL)
ok
Jan 14, 2011 | Sansui DTV2760 27" TV
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Motorola cable box remote codes
Its not going to work unless it is authorized by the cable company, and has the correct software.
Oct 17, 2008 | Motorola Televison & Video
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Jul 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Remote code for Hyundai Q320 TV
como funciona un control remoto universal para un tv hyundai
Feb 29, 2008 | Sony RM-V310 Remote Control
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Olevia 242T television
The code you want is 11610. Buy a remote that can accept this code.
Dec 01, 2007 | Televison & Video
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
