Question about Kenmore Oasis HE 27062 Top Load Washer
F1 error message comes on every time I start our washer after lid lock engages!
F1 error message comes on every time we use our Oasis washer right after the lid lock light comes on! After calling Sears service center and being told they will have to send out a tech at a rate of $100.00 for the assessment of the problem I told them they can send someone out however they can hold their hands on their butts as this expensive washer and dryer combo ($1900.00) which is only a year and a half old. We've have our previous combo for over thirty years before it needed to be replaced and nary a problem until the very end. What circuit board is bad and what are the steps to replace the same? The machine is great, however the service staff from Sears is with attitude unfortunately for them mine is worse!
  • bodo4847 Oct 03, 2008
    I called the number suggested 800-659-7026 (Sears Recall Department)twice and spoke with two different people. Jess was the first. He informed me that they did not have any information on a recall and said I should call the Federal Trade Commission to issue my complaint. He even gave me their number, 877-382-4357. The second call was to a Nan who also told me they did not have a recall and that I should try to call the manufacturer (Whirlpool)for a resolve of my problem.I informed her that I didn't pruchase the washer from Whirlpool I purchased it from Sears! She also added I could of course call Sears and pay for a service tech to come out to repair this problem! Yea right! It's time for a class action law suit!
    President:
  • 1,952 Answers
In response to the solutions which post the number to call, I just called 800-659-7026 and the representative said that my model will be included in the recall. The only Oasis washer not included is model 110.27082600. He said that corporate is tied up in litigation. He has no estimated date for legal issues being resolved. Contrary to the other solution where a technician is coming out to fix the problem free of charge, my service rep said he could arrange service but that it would cost $60-70 for the visit, not including parts.
I aired my disbelief at this, but all I got was touchy-feely "I know how you feel, and if I had a washer I would feel the same way, if only they could hurry up with this litigation and we can get it going!".
This is unbelievable. I will try calling again, and in the meantime, I am glad that my washer still works.
called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge.
Call this number 800-659-7026. It is Sears rework department. They know about the problem with the control boards and they are coming out to replace mine for free. It is almost 2 years old. I was told that they are sending out letters to all to notify everyone about the problem and how to get it fixed. already replace mine with my own money.
Posted on Oct 03, 2008
    Guru:
  • 558 Answers
HI there,
Thanks for using Fixya.
Generally "F.." appears in the display shows, then do the following:
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
If the fault message reappears, then it need proper diagnose.
You can contact to the other Service Engineer for its Repair which will diagnose the problem, carefully and cost you minimum, other than Sears.
Regards Ellin
  • Puneet Jain
    Puneet Jain Oct 03, 2008
    Let me know your City Code, so I can suggest you nearby Service Engineer.
  • Puneet Jain
    Here is the Service link for United States:
    Services
  • 13,433 Answers
F1 is a problem with the control board - you need a new control board
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors).
(http://www.fixya.com/support/t295790-kenmore_elite_oasis_top_load_washing)
  • Kenmore Master
  • 19,396 Answers
F1 error is primary error failure. This is often associated to problem with the control module.
First unplug power cord for ten minutes, and see if this clears the error.
If it does not work, start calling Kenmore at 800-659-7026, or using the number listed on the owner manual, on some model f1 is even caused from a factory defect and they will fix the appliance for free.
See here for example.
  • 1,029 Answers
THE PRINTED CIRCUIT BOARD IS BAD. DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS may cost you like $250
  • Starnley Johnwells
    Starnley Johnwells Oct 03, 2008
    hope this helps
    the control board is defective
    This simple test will help determine whether the printed circuit control board or the touch pad is defective when F1 error code is present.
    Note: Some models incorporate the touch pad in to the electronic range control (ER)C as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
    Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
    1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
    4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
    7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Right after the Lid Locks on both the wash and rinse cycle, the F1 light starts flashing and stops the cycle. We have to stop and restart at least 3 times for it to finally engage. Your suggestions...
F1 is a ( pressure sensor failure) which controls water intake in the machine control unit. The fix is to replace the machine control unit ( computer) This is an easy but costly repair..... At one time kenmore sent out letters to owners of certain models offering replacement of the computers Good Luck
Sep 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Lid does not lock will not take cycle instructions
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) from www.midwestapplianceparts.com
Jul 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The lid lock is broken, can it be unhooked, machine will not engage with lid unlocked.
Following is the Whirlpool service manual for their Cabrio washer, basically the same as the Kenmore Oasis.
It has a troubleshooting section as well as diagrams and instructions concerning the Lid Lock.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE getting F1 code. What does this indicate?
your board is confused and cannot read water level, very easy fix, pull off console(three screws on rear) and remove clear hose on right side of main control. blow into with your mouth and clear tube. reconnect hose and try, if F1 continues main control will need to be replaced, Sears is offering this for free if your unit falls within a certain serial number range, Also a biggie.....You must use he soap only with the oasis....no exceptions.....
Apr 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
F1 CODE COMES ON AFTER LID LOCK
THE PRINTED CIRCUIT BOARD IS BAD. I DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS MISTAKE COST $175.00. SO LIVE AND LEARN
Mar 30, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Error - LiD
Probably something wrong with the lid lock system. You should here a good sized click and the lid lock light should come on. If not, its probably a bad lock system. Good Luck!!!! Jim
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
169 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
