Quasar sxf2715j vertical out - Televison & Video
Posted on Oct 04, 2008
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
10 yr old Quasar 25in color tv. Audio is ok. No raster for picture, just horizontal electron beam trace across screen. No vertical deflection for picture display. Any suggestions other than using tv for...
Don't have specific knowledge about this model but the problem is in your vetical o/p section an is fixable.
In general read below.
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 22, 2009 | Quasar SP-2722 27" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Horizontal line problem
1. solder the vertical ic first. otherwise replaced the vertical ic.
2. solder the yoke wires.
3. replaced the vertical ic supply capacitor.
Jun 26, 2008 | Quasar SP-2723 27" TV
Vv 1220 screen shakes
Probable bad electrolytic capacitor in vertical circuit.....T.
To get more help from different experts, list your tv in the correct catogory....
All products>Quasar>VV-1220 Standard Television>
Oct 24, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Vertical lines in the picture
LOOK FOR A CRACK SOLDER IN THE PIN OF EVERY COMPONENT THERE IN THE VERTICAL AREA RESOLDER IT.
Jun 10, 2007 | Quasar SP-3220 32" TV
Quasar sp2722 27 tv
you have an intermittent vertical ic or caps . it will need service sorry usually it's not to expensive werepair these all the time
Apr 01, 2007 | Quasar SP-2723 27" TV
Quasar 32" TV VERTICAL HOLD
well most of the modern tv today doesnt have vertical hold anymore. this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Feb 02, 2007 | Quasar SP-3235 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
